Half shaft UJ covers
poprivet
Postby poprivet » Wed Oct 11, 2017 3:31 pm
I get an annoying light tinkling noise from somewhere near the left hand side near the rear and have never been able to locate the source. The UJ covers are very close to the exhaust pipes but don't show any rubbing or wear but I'm thinking of removing the covers to see if it makes any difference.
That got me thinking do I need the covers at all? Dirt gets in there anyway, inspection and cleaning of the joint is impossible and the prop shaft joints don't have covers. Now I'm sure Jaguar engineered them for a purpose but I can't think what the advantages would be.
Keep 'em or ditch 'em?
Re: Half shaft UJ covers
Postby Brakebuster » Wed Oct 11, 2017 3:49 pm
I never refitted mine when I put her back on the road, and no detrimental effects can be seen from not using them , then again , its not average mileage im doing either
your car, your choice in the end
rattling could be something completely different though , like a stone in the covers , lol
Postby davidr » Wed Oct 11, 2017 6:57 pm
Like BB I never bothered to refit mine when I rebuilt the IRS on my V12. They just got in the way so they're still on my workshop floor!
poprivet
Postby poprivet » Sun Oct 15, 2017 5:29 pm
Thanks both, I removed them without trouble. I also noticed that the heat shield above the central part of the exhausts was slightly loose due to a self tapping screw working loose. They are quite big self tappers and I had nothing bigger so I tapped the hole out to 6mm metric and fitted a bolt.
I'm pleased to say the rattle has now gone, I expect it was the heat shield but as you say, no loss losing the joint covers. Having those hose clips whizzing around can't be good for balance either so good riddance :D
