Page 1 of 2
Speedo Reading incorrectly?
Posted: Fri Sep 21, 2007 10:41 pm
by ptjs1
My car has always had P4000 225/60 ZR16 tyres on it, being a 4.0 litre convertible and, therefore, fitted with Touring Suspension.
However, I've always wanted to "tighten" up the car a bit and have some Bilstein shocks to go on it plus some Sports springs ready to go on the car. I'd also decided to change the tyres to teh slightler stiffer 225/55 ZR16 that were fitted to Sports suspension-equipped cars.
As two of the tyres needed changing this week, I've fitted 2 P6000 225/55 ZR16s. So I presume that I've now got a speedo problem...
This is because for all late 4.0 XJS models the speedos, transducers and gearboxes, ABS sensors etc etc are same irrespective of whether the car had sports or touring suspension. Which seems to imply that either sports suspension cars or touring suspension cars must always have been reading the speed incorrectly.
So, have I just made my car read incorrectly, or have I just corrected it?
PS It's the sort of thing that exercises the mind on a Friday night after the second bottle of wine!
Posted: Sat Sep 22, 2007 2:16 am
by Mark_B
I find a sat-nav (in my case a tomtom 300) is a good way of checking accuracy of speedo. In the menus somewhere there is a switch to activate a mph indicator. I found my speedo is out by a offset constant +4 mph, plus a percentage error of about +8%. The offsett error is easy to fix, just re-position the needle!
Posted: Sat Sep 22, 2007 7:42 pm
by dhdove
Hi Paul
According to my maths your car will now have a +5.8% differential on the speedo reading - ie will read faster than it did (assuming you put the tyres on the rear wheels.......... :twisted: ). Whether it is now "right" or wrong" I couldn't say.
However since ALL speedos may over-read, by, I believe, up to 12% in law, but NONE can under-read by any amount, I would say that if anything you will have exaggerated any error that was already present, ie you think you're going faster than you actually are.
My Road Angel has GPS constant speed readout and the speedo on my car consistently over-reads by approx. 5-10%.
An easy way to check is with the plethora of flashing speed warning signs littered around our roads. They are reasonably well calibrated, within a mile or two per hour, so, pick one that you drive past on a regular basis and test it against your speedo - when it flashes you're doing over the limit for that location.
I knew there had to be a use for them :lol:
OR......... buy a Road Angel, it's a super bit of kit, mount it on top of the dash, to the left hand side of the instrument binnacle and you'll never look at the speedo again - it's like having a head-up display of speed, also warns you of speed cameras etc............... :D .
Best Wishes
DH Dove
Posted: Sat Sep 22, 2007 8:56 pm
by ptjs1
Mark / dh,
Tks for your thoughts. I assume a GPS is really the only way to check it properly. I'm running TomTom on my smartphone, so I'll check it on that If it's not a silly question, can GPS systems be out at all due to the time lag of interpreting the signals or other factors?
I'm not that worried about my speedo reading incorrectly as I assume all car speedos are wrong by about 7%. Although interestingly my '94 Range Rover has always read exactly the same as my SatNav speed.
I'm more interested in the "anorak" side of things, ie which way did Jaguar build the cars originally? On the basis that there is a 7% difference between a 225/55 & a 225/60 tyre, did Jaguar calibrate the speedo originally on the assumption of a 225/55 tyre or a 225/60 tyre?
My guess is that because there are more 4.0 convertibles than 4.0 coupes or any 6.0 litre cars, then they would have set the readings up based on 225/60 tyres (?).
On that basis, then I would have now made the speedo over-read by about 14% instead of the original 7% as I've moved to a smaller rolling radius.
I'll post back when I've checked in on a GPS. In the meantime if anyone has any knowledge of how Jaguar actually did it, I'd be interested.
Tks
Posted: Sun Sep 23, 2007 3:31 pm
by dhdove
Don't know about Smartphone Systems but other GPS Systems should be very accurate, there will be an error up and downhill, I'll leave you to do the mathematics on that! (trig and geometry will sort it).
Yes, I would think that you are probably 10-15% out on your readings now.
IMHO Jag had been building coupes in greater numbers than Convertibles and I would guess the OME equipment is based on them, having said that, do the test and you'll find out!
DH Dove
PS my '89 3.6 Coupe speedo was absolutely on the mark............must be these dodgy Ford instruments.
Posted: Mon Sep 24, 2007 1:54 am
by Mark_B
can GPS systems be out at all due to the time lag of interpreting the signals ?
I understand it's the time lag between the respective GPS satellites is how the GPS system works. On board each satellite there's an atomic clock accurate to 1 second in a billion years or something like that, they're all synchronised together and send out identical time signals down to earth, which a receiver picks up then deduces where it is by the various delays between the signals.
Posted: Mon Sep 24, 2007 7:46 pm
by dhdove
Is it me..................?
According to your track day post you put the new tyres on the front.... :? in which case......................you may have a problem as the front wheels will have to go round much faster than the back ones in order to keep up.
DH Dove
Posted: Mon Sep 24, 2007 8:29 pm
by poprivet
Just to add a few other factors into the equation, as well as a change in the speedo, the overall gearing will also alter which will effect acceleration and top speed. As tyres wear, the effective diameter will become smaller and tyre pressure and tyre construction will also change things. Last but not least, a running tyre isn't round, its flatter at the bottom and theoretically the rolling circumference can increase at speed due to centrifugal forces, partially restrained of course by the centripetal force of the radial tyre belts.
Pop
Posted: Mon Sep 24, 2007 9:20 pm
by ptjs1
dh,
Well, er, yes & no....
The tyres that wore out were the front ones which I'm convinced have gone due to tracking although 2 main dealers and one independent have told me over the last 3 years that the tracking is fine. However, my tyre man has a £30,000 4-post wheel alignment bed and he says that a £150 tracking device vs a £30,000 device will give you relevant degrees of accuracy....but then perhaps he would say that...
Anyway, I ended up putting the new tyres on the back because of a tv programme that (I think) I saw many years ago which proved that if you only replace two tyres you should always put them on the back. Then I wrote the post on speedo inaccuracy. Then, when I checked the brake pads at the weekend in prep for the track day, I got nervous about where the good tyres ought to go and thought I should put them back on the front! THEN I wrote the post on Track day advice!
So, can anyone remember the programme which said on which end you should have the good tyres?
Pop, I've been thinking about the flat bits of the tyres and I have decided that I will turn two of the tyres through 180 degrees so that the flat bits are at the top which will cancel out the problem won't it.........?
Mark B, I've just noticed that .0001 % of air is Krypton which presumably is why you never see Superman driving a car......
Confused of Kent
Posted: Tue Sep 25, 2007 8:41 am
by Mark_B
Hmmm, it may be that 0.0001 % of the drivers on the road are actually Superman...
About 'tracking' : Something I found out many years ago is adjusting the toe-in (tracking) exactly to 'maker's specification' with the most expensive equipment isn't the best for getting maximum tyre life. If there's worn suspension parts or slack bearings it's all wasted, the common effect seen is the tyres wearing on the outer edges first and the tyre-fitter saying his usual "you're going into corners too fast" to explain it away, after the tyres wear out faster than ever and the steering wheel is not quite pointing straight any more! On one occasion I bought a newish Renault cheap that kept wearing out both front tyres on the inner edges within a few hundred miles, the car came with 3 new tyres in the boot ready to be fitted. The tyre place that set the 'tracking' was so adamant they set it correct (and said the usual 'your style of driving sir') that I was suspicious. So I genned-up on the subject of steering geometry from motor engineering reference books, like you do... I measured the toe-in myself and lo and behold the toe setting was set to the exact right number of millimeters, but get this.. it was set the wrong polarity, they set it for toe-in rather than toe-out (toe-out was unusual back then). What I learnt was if you have a car with unusual settings or construction you'll likely have trouble when you use the average motor fitter! I beleive the moral is- the most expensive measuring equipment is only as good as the intelligence of the software that runs on it. :-)
by Mark_B
I find on XJ-S that if the outer edges of the tyres are wearing too fast, it's likely that the top wishbone bushes or stubaxle is worn and despite the toe-in set correctly. Of course don't forget if the set-up changes (i.e. different tyres, lower springs etc) the 'specification' toe-in setting (and £30,000 investment of setting equipment) may not apply any more anyway! In that case it's probably a case of throw out the maker's settings and use the old 'remove toe-in a bit at a time until the wear patterns on the tyres even out'. :-)
Posted: Tue Sep 25, 2007 3:24 pm
by kelsham
Hi, Sometimes the correct setting can cause problems. Even so called specialists seem to be rigid in their interpretation of correct setting. If all the relevant bushes are in good condition the fact the tyres wear unevenly is telling you something is not working. I always use a Gunsons Trakrite alignment gauge. I believe they are about sixty pounds these days. The idea is that you drive the car over the gauge at walking pace. All the play is taken up when you begin to move forwards and the gauge tells you whether the wheels are toeing in or out. simple adjustment at the track rod end then remedies any discrepancy. Only failing is you need a flat surface to use the gauge. I have never had any undue wear after using my Trakrite. Of course if setting an XJS track dont forget to centralise the rack with an old drill in the hole provided. I then fix the wheel at this setting with tape and only move the wheel after settings are acomplished. hope this is helpful regards Kels
Posted: Mon Oct 01, 2007 10:01 pm
by Mark_B
Does anyone think there is a market for a Speedo Reading Correction Module that you connect into the car wiring ?
It's calibrated against a gps unit with speed indicator you trust, what you'd do is drive along a constant 30 mph and press a button on the module for 6 seconds, then the speedo jumps to 30, then drive at 70 press the button 6 secs to set that too. Then once happy with the readings the module is tucked away behind the dash and forgotten about.
For techy-types it measures the pulse rate from the back axle, calculates a corrected pulse rate and outputs it, which carries on its way to the speedo. It's 2-point calibration, the 30mph sets 'offset+30', the 70mph sets response 'slope'.
Dunno how much it would sell for, probably 40 ukp I guess. What do you think ? A good new product?
Posted: Tue Oct 02, 2007 5:45 pm
by poprivet
I'd certainly go for that if I ever have to change back to 225/60-15 tyres. I expect the speed interface unit does a similar thing as that changed part numbers with the introduction of the wider tyres (sportspack)
Maybe they did a similar thing for the facelift touring/sports setup?
Pop
Posted: Tue Oct 02, 2007 5:49 pm
by dhdove
Mark B
Have you just invented this you brainbox?
I think there could be a market for it - especially where cars have been modded to take alternative gearboxes, diffs etc - BUT you may fall foul of legislation regarding OEM Speedo calibration..........
In any event - I'm impressed :P
DH Dove
