IRS Strip Down and Rebuild
Re: IRS Strip Down and Rebuild
Postby davidr » Wed Oct 26, 2016 8:49 pm
Here's the cage after a coat of 2 pack black.
And the wishbones and other parts hung up to dry
Postby davidr » Wed Oct 26, 2016 9:02 pm
Once all the paint had dried I took all the parts back from Hollygrove (thanks for your help guys!) and started to rebuild.
If you recall, I left it back at the end of august having checked out the diff, given it coat of paint and building the brakes back on to it. Now it was time to bolt the cage back on.
As its much easier to do at this stage I first bolted the exhaust hangers back on. These go through a captive nut held in the cage and have a little keeper beneath. I used plenty of copper grease here as the captive nut will break free if I try to undo it later and the bolt has rusted in!
Then the moment came to start making to look whole again by bolting on the cage. Sitting the diff up on some wooden blocks gives enough clearance for the cage to go under the nose of the pinion and over the diff.
There are then 4 coned bolts to be torqued down and lock wired. Its important to get these tight as they will make a knocking noise if they come loose and oval out the cage.
Postby Brakebuster » Wed Oct 26, 2016 9:07 pm
lookin good buddy
gives a sense of achievement doesn't it ,
keep posting the pics
Postby davidr » Wed Oct 26, 2016 9:20 pm
Next the cage was turned on its back ready for the fulcrum mounts to be bolted to the diff. Here they are with their coned bolts.
Its important to clean all the paint off the machined surfaces otherwise the paint will wear away and everything will become floppy!
Then they are bolted to each side of the diff - only loosely at this stage.
Once they are in then I tapped the fulcrum pin through the cage and the mounts. The idea is to get everything lined up and then see how much shimming is needed between the fulcrum mount and the diff.
Then I measured the gap with a feeler blade.
In fact only the one shim was needed - all the others didn't need one. I was OK with that because that's how it was when I took it apart.
Then the bolt can be torqued up and lock wired.
And finally the spacer tubes can be pushed into place.
Throughout this I kept trying the fulcrum shaft to make sure it went in and turned reasonably easily just to verify that everything was lined up OK
Postby davidr » Wed Oct 26, 2016 9:37 pm
Now on to cleaning up the wishbones and putting the roller bearings in.
Here I'm cleaning out the thread for the grease nipple.
This is a thread cleaning kit that I bought a while ago. Its become one of the best tools I have. Not only good for cleaning up threads but also great for clearing my mind if I'm not sure what size and type of thread I'm dealing with. A bit of trial and error soon makes it clear.
The paint was cleaned out from the inner faces and then the bearings pressed in (writing on the outside). They are only pressed in so far to leave a channel in the middle for the grease.
I used my press (overkill!!) but it can just as easily be done in a vice - doesn't take much effort.
The original inner races were too worn so they were replaced. Below is one of the old ones with clear scoring from the needle rollers.
New ones were put in with plenty of grease
oldtimer
Postby oldtimer » Wed Oct 26, 2016 9:48 pm
David, First Class Job - Thanks for the pictorial report at each stage of the job - really appreciated
What a shame to have to hide it away under the car !
Postby davidr » Wed Oct 26, 2016 9:56 pm
Building up the oil seal and spacer washer is best done using grease to hold it together I find. Otherwise you need at least six hands to hold it all together when trying to put the wishbone in!
Here are the components - the oil seal assembly on top and parts below
The inner track of the oil seal fits over the inner race for the needle bearings so it is against the wishbone arm. The spacer washer goes on the outside. As I said, I found it best to stick this on with grease.
Counting out from the inside the layers are inner race tube, inner seal track, oil seal, outer seal track
Then it fits between the cage and the fulcrum mount like so. It still took many hands to keep it all together as I pushed the wishbone into place!
I am getting a little ahead of myself and I've just remembered that I bolted the driveshafts on first as its easier to do before the wishbones go on.
New metaloc nuts (NOT nyloc for obvious reasons of the heat in that area!)
The same camber shims were refitted as taken out. I will have to check the camber when the unit is back on the car - I can't think of way of doing it on the bench!
Postby davidr » Wed Oct 26, 2016 10:41 pm
And so back to Hollygrove who helped me to build up the springs and dampers.
I had an old set of springs and negotiated a new set of dampers from Tintin earlier in the year (cheers Robbie!).
Although I have a set of spring compressors Hollygrove have a special tool that makes much lighter (and safer!) work of the job.
The spring and damper are assembled and then put into the compressor. I like to use copper grease both to prevent rust and stop the top coil squeaking against the damper.
The compressor has a cone at the end that holds the spring but allows enough room to fit the lower spring support and collets in place.
Here's the bottom of the damper sticking through the cone of the compressor and the lower spring support in place.
One collet in place - it fits into a groove in the damper.
Both collets in place and then we carefully released the compressor making sure that the collets were properly seated.
As I said, I could have done this at home using conventional spring compressors but this way is much quicker, easier and safer with the added benefit that it does not damage the paint on the spring as a normal spring compressor would.
All 4 were done in about 20 minutes!
many thanks once again to my friends at Hollygrove Jaguar in Ringwood (01425 477000)
I think the Club tool hire scheme has a similar compressor?
Postby davidr » Wed Oct 26, 2016 11:03 pm
Those newly assembled springs and dampers were now fitted.
The bottom bolt has to go in the right way. It must be inserted from inside the cage with the nut and washer on the outside. If you do it the other way then you won't be able to get it out again when its on the car!
Here is the bolt shown without the damper in place yet just to make the point!
Nut and washer on the outside!
The tube for the lower damper pin is shorter on the front facing side than the other. This is so the special bolt for the radius arm can be inserted. There is a spacer to make the effective length of the tub the same at both sides. The radius arm bolt also has one side of its head missing so it will slide past the tube. Also note the position of the washers and that there is one as a spacer between the lower damper bush and the tie down bracket (the oval shaped bracket that goes between the lower damper pin and the outer fulcrum shaft).
I've put it together roughly as I'll be using the radius arms off the car as I know they're in good nick and I replaced the bushes a short while ago. What I used was original Metalastic large bushes but polybushes for the small ones. That way I get the right mix of compliance and firmness.
Postby ptjs1 » Wed Oct 26, 2016 11:28 pm
David,
Looking really good!
I'd strongly suggest that once it's all together, you take it for a full Hunter bed alignment. It may well need adjustments notwithstanding that you've shimmed and bushed it as per it was originally. I'm sure more by luck than judgement, mine was more accurately aligned after the rebuild than before!
Postby davidr » Wed Oct 26, 2016 11:30 pm
Next on was the hub assembly.
I put it in the wishbone and then measured the clearance as shown.
The hub is then shimmed at either end to centre it on the wishbone and prevent any movement. However, its a b****r of a job to keep everything together, squeeze the new felt seals in and not bend the shims when trying to get it in. A dummy shaft is used that is the same size as the distance between the 2 machined faces of the wishbone. This stops all of the shims, bearings etc from moving out of place and is driven out with the fulcrum pin. Still not easy!
Again, copper grease is the order of the day!
Lastly the splined shaft is inserted into the hub and the hub nut done up.
First make sure that the oil seal track and spacer are in place.
It may need some "persuasion" to come all the way through. The thick washer and slotted nut then went on. I did it up with a windy gun but I'll wait until the unit is on the car to torque it up fully. Can't really do it on the bench as there's nothing to push against!
I used the original slotted nuts that unfortunately I forgot to throw in the pot for zincing. I bought some new but they weren't as substantial as the originals. I'm afraid I've gone for function over bling here. I hope you can forgive me!
Once they are fully tightened they will get a split pin.
So there we are! Starting to get there isn't it?!!
Just the bottom tie plate to go on and then I turned it over to fit the brake pipes and handbrake return springs.
Postby davidr » Wed Oct 26, 2016 11:52 pm
Brake pipes being refitted. I used the same copper ones that I took off - nothing wrong with them. Just a bit of Racing Green applied to smarten them up!
And I've treated it to a new braided flexi-hose.
Handbrake springs and mounts fitted and there it is!!
And finally to bring this thread bang up to date here it is manhandled into the back of my wife's old Discovery yesterday. I've taken it down to Hollygrove as I don't fancy trying to do the swap on the floor in my workshop. A 2 post ramp and more pairs of hands is a much better idea!
My hope is that I can get this done in the next couple of days and a maiden voyage up to Saturday's Kemble meeting is a good objective!
Postby davidr » Wed Oct 26, 2016 11:55 pm
BB and Oldtimer - thanks for your encouragement!
PTJS1 - thanks for your comments too. I have a camber gauge that I'll try but if I think its very far out I'll take it to Julian at Micheldever Tyres. He has all the right kit and certainly knows his way round an XJS!
Postby Brakebuster » Fri Oct 28, 2016 7:28 pm
what a fantastic job !!
reminds me of a few years ago , and how i put it back in on my own , lol
just a thought, and a ' future help ? '
there are some brake bleed extensions that can be added to the rear brakes, do you have them, or considered them ? your brakes can be bled without the need for double hinged forearms....
Postby davidr » Fri Oct 28, 2016 9:43 pm
Hi BB - yes I have heard of that. If I'm thinking of the same thing then they extend from the inboard calipers so you can put the bleed nipple on the edge of the cage near the hubs. Main advantage is that you dont have to get under the car to bleed the brakes but I'm assuming that you'd still have to jack the car and remove the wheels? For me, getting under the car isn't an issue (I have a pit) so I haven't worried about it. Probably easier to use the pit than to have to take the wheels off?
David
