David,
Great pics as always! I know that you probably told us earlier but what is the finish on those handbrake parts? Is it some sort of passivated cadmium or similar? I fancy the idea of getting a load of parts done.
IRS Strip Down and Rebuild
Re: IRS Strip Down and Rebuild
i to would like to get a load of parts done,
such as the V12 fuel rail and associated throttle link parts , and some other engine bay bracketed etc , so so concerned about the parts under the car
I put the dti against the inner face of the disc. If you recall, I felt that the old discs were in good enough condition to put back on. Although they had some surface rust that I soon took off with a wire brush on the angle grinder, they had no wear or lipping at all as they were fairly new.
(PS Don't get confused! That's my Celebration in the background - this IRS is destined for my 1989 HE)
As you can see, run out on one was between 7 and 8thou and the other wasn't much better. My target is less than 2 thou so not acceptable! I tried the discs on several times and ways round but never got them within the tolerance I'm looking for,
Just to be clear, all surfaces had been meticulously cleaned to make sure there was nothing that could affect the alignment. All four nuts were also tightened using the windy gun and instead of the thick washers I'd used earlier I found the top portion of an old half shaft and used that so all 4 nuts were tightened up.
I took it apart again and tried it without the shims. It was better but not good enough. I'd thought that I could clean up the shims on the wire brush and re-use them. There is still some corrosion on them but I thought them worth a try. bad move! So I think I should invest the £8 for 10 new ones then!
I've also reached the conclusion that a new pair of discs would be a good idea too. They're not that much after all and I think these are perhaps warped.
So, another shopping list!
Not that fiddly really. The first side took me some time but that was mostly because I was taking photos all the while. I took it apart again because I assembled it first time without grease etc because I wanted the photos to be clear. The second one went together in 10-15 minutes.Fiddly little blighters?
Now I know why I put my old V12 XJS out to Jagcare when I had a handbrake problem with it!
When finished, you will probably have one of the finest rear cage units fitted to any XJS. A massive job and not for the faint hearted.
Mike - I think this is all rather more straight-forward than the work you've been doing on your X350 XJR supercharger!
Its a zinc chromate finish. Older parts may have had a cadmium finish which has a similar golden/green/red/blue finish. Don't ask me the chemistry!David,
I don't think the cadmium finish is available any more - elf & safety I expect!
Its not that expensive. The key to it is preparation.i to would like to get a load of parts done,
There would be some sense in getting together and pooling bits to be restored. The price is pretty much the same however much you throw in. Whenever I've done it I've chucked all sorts in. That lot that I pictured and a good few more bits cost me £40.
David,
again apols if you already told us, but did you blast clean all the items before submitting for plating or did they do the cleaning?
All parts were thoroughly cleaned and de-rusted on the wire wheel to get them as clean as I could. Ferndown Finishing then acid-dip them to get them really clean before they're plated
So, a pair of Pagid discs from Euro Car Parts and some new shims from Hollygrove in Ringwood and I'll try again.
I've gone about it a different way this time. First I've centred the disc by adding shims to ensure that the gaps between the disc and the caliper shoulders on both sides of the disc are within 10 thou of each other. It took a bit of juggling and the assembly had to be dismantled a few times but I got them both within acceptable limits in the end. With the caliper bolts done up and the discs nuts torqued up I attached the DTI magnetic mount to the caliper and measured the run out on the outside of the disc. Good news was that run out on both sides was less than 2 thou which I feel is acceptable.
So now I could check that the caliper bolts were tight and lock wire them. Now all this is done the handbrake calipers can be added
They slot into the main calipers and the brass spring fork presses into the small holes in each pad carrier. Its job is to push the pads apart when the handbrake is released. Then the lock tab is placed on top and the 2 bolts go through the lot. You'll see that most of the pin is unthreaded so the caliper can pivot on it and the threaded portion at the top goes into the main caliper. I used copperslip on this to make sure it doesn't sieze. Once the bolts are tightened, the lock tabs are turned up to prevent then shaking out. Now the pads can be adjusted inwards using a screwdriver and then the split pin inserted as previously shown. It can be bent back now. So, here is the diff with brakes fitted ready to be installed in the cage. I guess I'd better get on and paint the cage, wishbones etc!
I'd been waiting for ages for some new taper roller bearings for the lower fulcrum shaft in the hubs to arrive. Finally they have so I can complete building up the hubs and carriers.
Here are the bearings and outer races. The outer races are inserted into the hub carriers here. You can see the 2 cutouts either side where a long drift can be used to knock the old ones out.
I had a choice of 3 methods for pushing the outer races in. Again, remember that these are taper roller bearings and pull in against each other so get them the right way round!
First method is to grind down an old race and use that as a mandrel to tap the new race in with a hammer. This stands the chance of not going in straight and either binding or damaging the alloy hub carrier. Second is to use a suitably sized socket and a 1/2" extension - again apply percussion. This is more even but requires you to hit your precious tools! Or finally, if you have access to a press then use that. You've more chance of it going in straight and its more progressive and gentle.
Once the outer race is pressed home the spacer seal goes in next. Its a little confusing what goes where at first (especially if you weren't paying attention when you took it apart!) but its important that everything goes back in the right order.
Then the roller bearing is thoroughly greased and inserted. By thoroughly greased I mean that grease is worked in between the rollers and not just a big blob daubed on the outside.
Then the oil seal shell can be tapped in as shown (and not reversed!)
This is now ready to accept the felt seal as below and the oil seal track.
And finally the retension washer slips over the oil seal track.
Repeat on the other side.
I then used some of the washers and spacers from other parts of the assembly to pull it all together.
Now's time to start thinking about preload. On the main hub bearings they were set up for end float ( so the hub can rattle about a bit between the bearings ) in order to give a little room for heat expansion.
For the pivot we need a little preload - in other words the bearings are pulled against each other by between 0 and 2 thou.
This is done by means of shims on the end of the sleeve that goes through the carrier. The bearings are tightened onto this at either end so its length is varied by the shims to move the bearings either closer by taking some out or further apart by adding some.
Below is a picture of all the components for one side. What's not in the picture is the sleeve that I was talking about. D'oh!! Sod it. I'm not taking it apart again!
Here's another picture with all of the components on the pivot pin in order. From left to right (ie order of assembly) pivot pin sleeve, pre-load shims, taper roller bearing, spacer seal, oil seal shell, felt seal, oil seal track, retension washer, shims for centralising the hub carrier in the wishbone and the nyloc nut.
I assembled the whole thing with too many of the smaller shims against the sleeve so there was end float. I then measured that end float by putting a feeler gauge between the large washer at the end and the hub carrier. Then I take enough shims out to give the small degree of pre-load required. I hope that makes sense!
Thanks for posting this thread. Your descriptions and pictures are excellent. Even a mechanical novice like myself can follow what you are doing and learn something. Haynes has competition!
Ex 2010 XF 3.0 Luxury Diesel
Ex 2004 XK8 Coupe
Ex 2004 XK8 Coupe
Wow! Was it really the end of August when I last updated this thread?!! Oh dear!
Well you'll be pleased to hear that I have made some progress since then!
I'll pick up the story with painting the cage, wishbones etc.
Here we are priming the cage. But first we had to weld up and repair a small split in the cage and I decided to go round grinding off the weld splatter from when it was first made.
Here's an example of the weld splatter And here is the small tear that we repaired And here's the cage and bottom tie plate in primer All the other parts such as wishbones etc were also primed
You may recall a discussion we had earlier in this thread on the relative merits of painting versus powder coating.
When Hollygrove sent my cage etc away for blasting they had one from a 1961 E Type that they are restoring and we had the blasted at the same time.
Interesting to note that the basic design of the IRS is the same for the 1961 E Type as for my 1989 XJ-S. Just that the E Type one is narrower.
What was apparent was that the E Type parts were in much better condition and this wasn't because the E Type was a pampered car. When I saw it before the restoration started its boot floor had completely rusted away!
The top surface of the E Type cage, seen below after blasting and in the green/yellow primer coat the blasters had flashed across it, has a good surface that will paint up perfectly. Contrast that with mine shown below in red primer. The surface has pitted with rust and its nearly 30 years younger! The difference? In 1961 the cages were painted. In 1989 they were powder coated. Once the powder coat starts to deteriorate the moisture gets under it and sits against the metal quietly eating it unseen.
So for my money that's the debate settled - paint it is!
