Speedo Reading incorrectly?
Mark_B
Postby Mark_B » Wed Oct 03, 2007 9:59 am
Just thought the concept up, quite do-able technically (whatever the speedo is meant to read!)
I must admit I don't think I understand the legal requirements, I'd always thought speedo meant to read close as possible to actual speed, now it seems there's a requirement to 'provide a slightly high reading, should there be any chance of there being a measurement error ', have I got this right ??
I would of thought when using standard/factory modification parts which affects the calibration, there are already available replacement electronic modules to restore the calibration (e.g changing from 3.54:1 to 2.88:1). The problem is when different setups/combinations of transmission/tyres are significantly different from a standard set up and accumulative errors remain. This module is meant to mop up the errors.
Anyway legal requirements I think can be complied with, I see more a problem with marketability, there needs to be enough interest and a market first...
XJ-S 3.6 230k miles +
Postby ptjs1 » Thu Oct 04, 2007 1:19 pm
Don't understand the legal position on speedos. I always assumed that manufacturers erred on the side of caution so they wouldn't end up in American courts being sued br drivers who got nicked for speeding because thier speedo was under-reading.
Anyway, Mark, I'll have a gizmo for £40 assuming it's not going to be a pain in the arse to fit, and is a reversible procedure in case it goes wrong one day. Actually, because I've ordered one of the very first models, presumably I can have it cheaper or free because it will be a pre-production model and you'll want user feedback from me......?
dhdove
Postby dhdove » Thu Oct 04, 2007 5:31 pm
:lol: :lol: :lol:
Mark
my understanding of UK speedo calibration requirements is that any speedo may over-read by up to 10% (and nearly all do), but may not under-read AT ALL.
DH Dove
XJS Bulletin Board Moderator
Mark_B
Postby Mark_B » Fri Oct 05, 2007 9:22 pm
I can see where the car manufacturers are coming from, for them to make the speedo to always read +5% would be the ideal, so as to maximise margin for error. Thinking about this... my freind who'd been pulled over for speeding on the M25 was told by police unmarked car driver he clocked doing 98 but my friend believes he was really doing 110 (& kept it to himself).. and all those other familiar stories.. hmmm ....
As far as the module goes, instead of speedo reading 30 / 70 it could read 31 and 72. How I see module is matchbox sized, 4 wires: ground, power, and the other 2 splice either side of a cut wire on way to speedo (or should it be near the thingy in the boot sending signal to trip computer and speedo?). I think it'll have 2 buttons on it to calibrate it, so there's a practical problem to start with - how to get to the buttons, maybe the module can live in the boot and a pluggy-in thing with a long wire temporarily plug into it that can be button pressed at the right moment. I'd be happy to mail a prototype out to anyone who'll help develop it by testing it etc. (Paul ?)
Postby ptjs1 » Sat Oct 06, 2007 8:52 pm
Mark,
I'm not abosulutely certain what is producing the final signal en route to the speedo (I'll try and work thru' the wiring diag soon). So the cautious part of me says interrupt as near to the speedo as possible. It's not difficult to drop the instrument cluster ina facelift car, but it is a bit tight behind and underneath the cluster. I had the lower trim panels off recently to trace the wiring route on the immobiliser and there's not a lot of room to play with under there. I'll see if I can drop the cluster during the week and find if it's easy to intercept the speedo wires around that area. It feels as if this would be the best place for the initial calibration process unless we can easily fit a temp long lead from the boot for calibration purposes and do a final position of the unit in the boot (assuming you know that an intercept at this place will definitely pick up the final signal for the speedo)
If we can work it, I'm happy to play guinea pig for the trial.
I'll have a look around the instrument cluster this week and post back later.
dogbitedavie
Postby dogbitedavie » Sun Oct 07, 2007 12:04 am
just for your info.
the police usually allow 10%, plus 3mph, before they do anything, although when on a purge they will be stricter. also, different forces vary.(and different officers, good day/bad day etc!)
so you can generally travel on m/way, with your speedo showing 80mph, with no fear at all. ( more, depending how far out your speedo is.
satnav speed readings are as accurate as the police vehicles, so if you have one fitted, youcan generally travel at the 10% + 3 mph faster, (NOT guarenteed ! and i dont condone speeding!!)
although their speedos are calibrated regularly, they check them by going past the 1 mile markers on the m/way, and timing it. e.g. 1 mile @60 mph takes 1 min.
also be aware, that they can measure the time it takes you to travel between two fixed points to calculate your speed,(whilst hidden away!) so you dont have to be followed to be caught for speeding, best thing is not to speed at all!!
Mark_B
Postby Mark_B » Sun Oct 07, 2007 6:47 am
Yes I seem to remember the 3 + 10% figure, though I have heard of people receiving points and a fine for doing 34 in a 30.
I think somehow the objective of a 'module' should be not change the speedo reading from how the manufacturer originally made it (i.e. +5% TBC), but instead to restore this operation after the fitting non-standard wheels etc. However, if the user wants to make the speedo read spot-on they can if they wish and if so complying with requirements of the law is their responsibility.
Paul, my understanding of the signal path is a magnetic sensor on the rear axle feeds a small signal to the existing unit in boot left side via a sreened twist pair, where it's amplified to 5 V or poss 12V levels. Coming out is separate feeds going to the trip computer and speedo, one of the signals is being divided in frequency by 6(?), by the existing unit in boot. It would make more sense correcting the trip meter as well by the same amount, if so that might mean the module would have to go in the boot next to the existing one. Maybe the module could be an exchange of the existing unit?
Mark_B
Postby Mark_B » Wed Oct 10, 2007 11:27 am
Update: found speed signal from amplifier module in boot. It's scaled 2.1 Hz per 1 mph, 5V logic levels with 1.5 ms rise/fall time.
I plan to alter an existing amplifier module (normally located in boot). If anyone would like to volunteer supplying a spare one to me, I'll use it as basis for a prototype!
poprivet
Postby poprivet » Wed Oct 10, 2007 5:57 pm
It just so happens I have one, DAC4864 which I believe is for the pre sportspack 3.6 which you can conduct dastardly experiments on if you so wish. :o
Send me a PM and I will post it (lord knows how long it will take to get there though) Just looked on David Manners, crikey there over £100
Pop
poprivet
Postby poprivet » Sat Apr 12, 2008 5:02 pm
Mark, did you have any luck with this project?
I would certainly be interested in a modified unit for use with 225/60 tyres.
Pop
Hosier77
Postby Hosier77 » Sat Apr 19, 2008 12:09 pm
Just thought i would poke my nose in;
The construction and use regs in this country are slightly different to most other places, for instance in the rest of europe the spedo accuracy must be +/- 5% but here it must be within +10%. But thats just for the car maufacturers.
The road traffic act says thet speed limits are absolute, so even 1mph over the limit is illegal, it is not an excuse to say your speedo read wrong.
The police take a more pragmatic view and generally allow a margine of error, but if they see someone who is obviousely driving like an arse but there is nothing else then can technically do them for then they may do them for a small speeding offence.
Users browsing this forum: No registered users and 14 guests
