Fitting Speedline Wheels
JAGW01
Postby JAGW01 » Wed Mar 14, 2007 8:24 am
:?: Can anybody tell me if it is possible to fit 8Jx16 with 33mm offset wheels to both front and rear of my 1994 6.0L coupe? If it is possible, what size tyres can be fitted? Is it possible to still use the standard 225/55ZR16 P6000s that I have? The car is currently on, Ipresume< the factory fitted 5 spoke alloys 7Jx16 with 28.5mm offset. :?:
Jon
Postby Jon » Sun Mar 18, 2007 11:27 am
I think you will struggle with wheelarch clearance at the front.
See this topic;
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... =speedline
CLEAN old '87 XJ-S 3.6 manual (for sale!)
If no-one buys it soon, its going on classic insurance!
'96 XJR manual (the green monster)
JAGW01
Postby JAGW01 » Sun Mar 25, 2007 10:31 am
Thanks for that Jon,
The link gave some interesting info which I had missed previously.
The 8Jx16x33mm offset JaguarSport wheels go staight onto the rears - no problems.
The fronts don't! The inside of the rim fouls the front of the top wishbone on full lock.
Tyre clearance doesn't seem to be a problem - they are the same size as on the original 7Jx16x28.5mm offset wheels and don't touch the arches anywhere.
:?: Do you know if it is possible to adjust the stops on the steering to restrict the lock slightly? One of the posts in the link you gave me referred to stops on the XJR-S cars, but didn't give any details.
John
Jon
Postby Jon » Mon Mar 26, 2007 5:48 pm
I never investigated the 'lock stops' further as the 19mm offset wheels seemed to fit fine.
However the wheel / tyre combination with my squidgy original steering bushes made the car tramline so badly it was no fun to drive. And that was the end of my speedlines. :cry:
dhdove
Postby dhdove » Mon Mar 26, 2007 6:56 pm
JAGW01
Hi, welcome to the site....
Purely out of curiosity (nose-iness), why do you wish to fit larger wheels??
Cosmetic reasons? You already have a set of wheels that you wish to fit? You want to go racing? or your car is sliding around too much on it's existing boots?
My reason for asking......... is that in my experience the manufacturer spends a lot of r&d time sorting the handling/performance of the car for optimal use prior to releasing it to the unsuspecting public. :D
I think Jon's comment about tramlining illustrates the problems you can encounter....
Obviously it's your prerogative to alter the spec. and the best of British to you, but what do you want to achieve?
Yours...........being nosey.... :wink:
DH Dove
XJS Bulletin Board Moderator
JAGW01
Postby JAGW01 » Mon Mar 26, 2007 9:40 pm
Thanks for the replies! It's good to know you're not on your own.
The reason for looking to fit the wider wheels was that I have obtained a set of 8Jx16x33mm offset JaguarSport wheels with reasonable tyres for less than the cost of refurbing the original 7Jx16x28.5 five spokes which are scabby.
I must agree that the car handles really well on the OEM wheels and I wouldn't want to detract from that for a bit of paint on the wheels!! I am not looking to go racing or to pose, I just want the car to be about right.
I think that the wheels I've got must have come from an XJR saloon as they are all the same spec. 8Jx16x33mm offset with 225/55ZR 16 P6000s. I wrongly assumed that as the tyres were the same that the wheels would fit straight on.
Can you use spacers on the fronts to reduce the offset? H&R do a 15mm each side arrangement that would give an 18mm offset. - I understand that the racers use this type of set up, but I note Jon's "tramlining" experiences in road use.
All info gratefully received.
John
poprivet
Postby poprivet » Tue Mar 27, 2007 2:39 pm
This link might be of interest,
http://www.jag-lovers.org/xj-s/book/1999XJRwheels.html
There was some discussion at the time, have a search on JL to find out more.
Pop
JAGW01
Postby JAGW01 » Tue Mar 27, 2007 8:53 pm
Thanks Pop,
I've looked at the link and the associated stuff on JL - very interesting!
The wheels in the first photo I am familiar with as I had a 1998 XJR. They are 8Jx18(don't know the offset). It is possible that the extra wheel diameter would move the rim far enough away from the suspension components to avoid a clash with the same width and offset. I note that spacers were used.
I think I my go down the spacer path so that I can keep all four(five) wheels the same and interchangeable, besides I have loads of tyres!!
John
JAGW01
Postby JAGW01 » Thu Apr 05, 2007 11:01 am
Hi, I've tried the H&R spacers that are sold as being suitable for Jaguar wheels and hubs - they aren't! The spacer bolts onto the hub using a special set of nuts and has its own set of studs already fitted to take the roadwheel. The nuts are proud of the wheel mating suface when fitted and therefore the roadwheeel cannot be fitted. :(
I've put the wheels up for resale and will stay with the original specification. Lesson learnt!
Thank you all for your contributions.
John
dhdove
Postby dhdove » Thu Apr 05, 2007 6:12 pm
John
Sorry to hear that, never mind, if you like the design of the original equipment wheels check out "Wheel Deals" in the general section 17-06-2006.
Mine are now nearly a year old and there isn't a mark on them, no corrosion, no flaking. They're just like the day they were fitted :D
Excellent service and a good price - I'm well pleased.
DH Dove.
poprivet
Postby poprivet » Sat May 26, 2007 11:14 pm
JAGW01
Postby JAGW01 » Mon May 28, 2007 10:54 am
Thanks Pop!! :D
I thought that I'd gone "bling" with a new set of OE chrome wheels from JDHT - made in the USA of course!!, but I wasn't that bold!! :lol:
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 2395-4.jpg
dhdove
Postby dhdove » Mon May 28, 2007 11:01 am
JAGWO1
WOW :shock:......... Had to nip out and get my sunglasses!
They look like the dog's doo-dahs!!!
A large tube of Solvol-Autosol for you I think..........
NB Are you going to Cadwell Park 7/8 July?
Best Wishes and happy polishing
DH Dove
JAGW01
Postby JAGW01 » Thu Jun 21, 2007 11:29 am
Hi DH,
Sorry about the long gap due to uncertainty over Cadwell Park, but I will not now be able to go. The next JEC thing on the horizon for me is National Southern Day 19.08.07.
I'll just keep right on polishing!!!
John 8)
dhdove
Postby dhdove » Thu Jun 21, 2007 4:54 pm
JAGW01
See you on the 19th then, God willing
DH Dove
