Little or no Heat from Heater
sheldon1
Postby sheldon1 » Thu Oct 29, 2015 9:31 pm
I have a 2000 3.0 SE S type and find that the heater is not currently working or giving limited heat.
Where should I look first to correct matters?
paul
Re: Little or no Heat from Heater
Postby J44EAG » Thu Oct 29, 2015 10:17 pm
I`d suspect the heater valve which is located to the rear of the radiator on the right hand side just above the anti roll bar bush saddle. It is a pig of a job to remove as you need to get under the car to extract it. It is really a Jaguar specialist job both to test and replace. Not a nice one at all. Thats one idea about the failure.
The other place to look after detecting hot and cold motor drive current is the wiring loom behind the front bumper and above the N/S front wing much shield. The shield has to come off to allow the bumper cover to be removed. Expect all under car fastenings to be corroded solid......
Sorry not to be more helpful. I suggest you take the car to an independent Jaguar garage for assistance, Paul.
sheldon1
Postby sheldon1 » Thu Oct 29, 2015 11:22 pm
Thanks Mike.
rosemary
Postby rosemary » Sun Nov 01, 2015 2:32 pm
Mike is right go to an Independent and get the heater control valve replaced,its a rotten job underneath the car and real fiddly you might be lucky and the ECM hasn't burned out. See previous Posts ref Climate Control/Heater. This is a common problem. Worth sourcing the valve and ECM( if needed) on the Internet, Ebay etc.
Dave Hart
jeff1954
Postby jeff1954 » Sun Nov 08, 2015 6:13 pm
Are you only doing short journeys, Is there enough water in the system?
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
