Cabin air flow
thomas45
Cabin air flow
Postby thomas45 » Thu Jun 25, 2015 1:47 am
I am having a problem with lack of air flow from the centre dash vents.
The end ones on each side, drivers and passenger work ok but nothing comes from the centre ones and the control wheels are in the open position.
The A/C is on and blower position is selected on the touch screen in Climate contol. The pollen filter has been examined and found to be clean .
I am wondering if some pipe is disconnected and if so is it likely to be in the bulkhead in the engine bay or behind the cabin vents.
It might be easy to remove the cabin centre vents unit but I hesitate as the woodwork could suffer. I think it has never been touched at that point as the woodwork is unblemished. Of course the problem may be caused by something unrelated to pipe/duct and I hope someone can enlighten me.
This is on a 2007 diesel.
Thanks, Thomas45
Re: Cabin air flow
Postby J44EAG » Thu Jun 25, 2015 6:09 am
Possibly a corroded or broken cable behind the front bumper, a blown blower fuse or heater control module issue. Montana is our guru on this type of problem. No doubt he will comment shortly.
vernon
Re: Cabin air flow
Postby vernon » Thu Jun 25, 2015 9:04 am
Listen for a ticking/clicking sound near the dashboard. If you can hear anything it is probably a faulty flap control motor.
Not uncommon on modern S types, (mine is stuck open). I can live with mine, not worth the time to replace.
Good luck.
Vernon
Nostalgia Classic 120
Modern S type jag
thomas45
Re: Cabin air flow
Postby thomas45 » Sun Jun 28, 2015 6:54 pm
Thanks Vernon & Mike, I will consider those possibilities and may have a look at them although could live with it.
Thomas45
