Sat nav screen
vickerp
Sat nav screen
Postby vickerp » Tue Jul 01, 2014 9:28 pm
Wondered if anybody had retro fitted sat nav screen ,to 2002 facelift 2.5 se model, is it a straight swop, I have cd changer in boot,
Montana5
Re: Sat nav screen
Postby Montana5 » Thu Jul 03, 2014 1:56 pm
Not sure its quite so simple. You will need the Sat Nav DVD Reader (middle unit) as seen in this picture...
I believe you also need the special cable to go from back to front and depending on which type of Climate Control Panel you have existing, might be far too expensive and time consuming to make it worthwhile.
This is an excellent guide to retrofitting the Sat Nav and Touchscreen, fitting is to an X Type but should be exactly the same for the S.
http://www.jaguarforum.co.uk/f103/retro ... -7735.html
Doug.
S Type Forum Moderator
vickerp
Re: Sat nav screen
Postby vickerp » Fri Jul 04, 2014 7:44 pm
hi Doug
thanks for the info ,guess I will stick with getting lost every now and then :)
s type 2.5se
jeff1954
Re: Sat nav screen
Postby jeff1954 » Sat Jul 05, 2014 8:37 am
Buy a Tom Tom the are more accurate.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
