Posted originally by dcsmoss
Hi,could anyone tell me how to retrofit a cd changer in my 3ltr man 2000 s type ....i have the cover (glove box interior for the changer)but do not know the make and model number of the changer....there is some additional hard wiring in the boot but i think that is for the sat nav which i will also be looking to retro fit if possible....any and all help is very much welcome .....my location is in west wales near to a village called crosshands so any one is welcome to email me dcsmoss@ukonline.co.uk to help, chat or meet up
cheers ,
Glove-box CD Changer
You have me foxed with this querie. To my knowledge and having consulted a Jaguar overview on the S-type, the only audio cabling accessable for a CD unit is on the nearside of the boot compartment. All S-types I have owned have the Jaguar CD player linked to this wiring.
I wonder if the reason you wish to install a glove box CD player is because the radio/cd control on the dash does not have a CD slot incorporated? I know this is a little frustrating as it requires loading the player in the boot when you want to change a disc. I think you may have to live with this odity as to install a different unit into the car "electrical architecture" is going to be a long, difficult and extremely expensive operation.
It is curious why Jaguar installed a tape player in the dash when the trend even back in 1999 was definately towards the CD as a norm. A CD slot would have been a much better idea. Ten years on from 1999, I can`t remember when I last used an audio tape. I suppose things have moved rapidly since the car audio was first conceived.
Mike Kennedy. JEC S-type Co-ordinator.
CD Changers - Boot and Glove box.
Re your glove box CD changer..... my '99 S Type had the CD changer in the glove box.
New problem....
I have recently 'swapped' my '99 S Type for an '03 S Type. I have discovered that the boot mounted CD changer does not work. The dashboard display says CDC No disc. I have loaded 1 or 6 cd's the correct way and tried various things to try and get the 'head unit' to see the CD's but to no avail. I called a local Jag specialist and he said he would probably have to replace the unit at a cost of £300. I have also logged on to www.breakeryard..... but without response. Does anyone have any suggestions? Thanks Keith Haward (Amersham)
New problem....
Mike,
My S Type also has the 6 CD changer in the glove box, I think this is because the Sat Nav and Premium Sound amplifier hardware is installed in the boot so there was nowhere else to put it if these options were chosen.
regards
Goss
Mike,
regards
Goss
