Sat nav
k42tut
Sat nav
Postby k42tut » Tue May 22, 2018 7:42 pm
Hi ,
Currently on the jec tour in jersey, my sat nav disc is the original that came with the car, 2004 car, 2003 disc,
Came off the ferry and no map, does not appear to cover the Channel Islands, seems a bit hard to understand when it's got all the rest of Europe on it,
I believe that the C I are included on later discs
Tried messing with the settings , taking disc out etc,,
Any ideas
2004 s the 2.7se , owned since new and still working
rosemary
Re: Sat nav
Postby rosemary » Wed May 23, 2018 7:41 pm
Hello k42tut
Your assumption is, I think, correct, Channel Islands is not on your disc. It's not on mine, both original discs and newer ones I've purchased.
When changing "search area" on the Nav Menu, Channel Islands doesn't come up. The same applies to the Isle of Man. The Shetland Isles are shown though. I suppose the thought is that if you keep driving you'll go in a circle and end up where you started anyway except Shetland where you drop off the island.
Contact www.satnavdisc.co.uk, info@satnavdisc.co.uk for further information.
Dave
Dave Hart
k42tut
Re: Sat nav
Postby k42tut » Fri May 25, 2018 1:30 pm
Hi Dave
Yes it's not too hard to find your way around on Jersey so could be worse, was just surprised it wasn't there originally, will consider update disc but not usually a problem here and a bit wary after hearing stories of copied discs not working and corrupting the system
jeff1954
Re: Sat nav
Postby jeff1954 » Sat Apr 27, 2019 12:31 pm
Just out of interest has anyone tried one of these disks, and is there any truth in it when people say that an after market disc can damage the system.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Zennan101
Re: Sat nav
Postby Zennan101 » Sun Apr 28, 2019 11:22 am
Hi Jeff,
I have upgraded twice using aftermarket sat nav discs without any problems either with install or operation. The upgrades work just as well as the Jaguar originals. That’s the good news the bad news is that the Jaguar sat nav software is pretty poor and slow compared with latest offerings and the upgrades simply replicate this.
I just checked my latest after market upgrade disc and can confirm that, like the original, there are no Channel Island maps.
Rod
Ex 2010 XF 3.0 Luxury Diesel
Ex 2004 XK8 Coupe
drcsmith2@hotmail.com
Re: Sat nav
Postby drcsmith2@hotmail.com » Wed May 01, 2019 12:52 pm
Hi Rod,
which aftermarket disc did you use?
Christopher
Zennan101
Re: Sat nav
Postby Zennan101 » Wed May 01, 2019 2:42 pm
Hi Christopher,
Sourced off EBay. Seller name Satnavsaver. £29.99 plus postage.
Rod
Ex 2004 XK8 Coupe
