i have had intermittent issues with fuel starvation , this manifests its self on long smooth roads and i get a stall or a stutter in the engine, i traced the fault to the fine mesh filter on the end of the pickup tube in the sump tank getting blocked up with fine debris from the fuel tank , funny thing is, on bouncy city streets or undulating lanes, this issue doesn't arise, probably from the fuel being bounced around keeping any debris suspended in the fuel rather than clinging ( sucked onto ) the pick up tube filter
so , i decided to find a replacement tank , i have been looking for years, missed a few on ebay for various reasons, but last week my luck was in and a new old stock one came up on ebay , it had actually been fitted to a car, but never got back on the road, the tank came with the sump tank and the fuel sender to , and everything was in great condition ,
I stripped everything down , and decided to paint the tank before installing it into the car , for added protection and to give it a longer life , a bit of rubbing back with some wet and dry , and masking off, and sprayed with hammerite smooth black paint, a few runs , but hey , its all hidden , lol
the side foams were glued back on today , and i test fitted a new breather pipe for the sump , it was bought years ago , but as my own breather pipe nut has rounded off and stuck solid , i decided not to fit it, and risk damaging my old tank
below is the pic of the new tank , all painted up and ready to fit
IMG_2449 by MyPix on Talk Photography
IMG_2454 by MyPix on Talk Photography
i have some new rubber seals for the tank sender unit, they are the same as the seal for the pickup tube in the sump , this pic shows the interior with the new seal waiting for my original sender , unless i find a new one ,as can be seen , practically zero corrosion inside
IMG_2453 by MyPix on Talk Photography
removing the tank sender or sump tank pickup locking ring is really simple, just get a tool to hold to one of the three tangs, and give a firm tap anticlockwise, the ring will move and come away from the device, and then pull from the tank the rubber seal will be behind that
IMG_2451 by MyPix on Talk Photography
just got to find a few weekends strung together to complete the project
