pre he injectors
Posted: Mon Nov 24, 2014 7:36 pm
by keri
does anyone have any v12 pre he injectors the ones i require are the early ones with the fuel pipe crimped to the injector with a deep ferrule the ferrule about 1/2 inch in length the later ones have the pipe just pushed on with a small dished washer on the bottom for appearance only i have been told although interchangeable the fuel delivery amount differs from both these and vthe outlet pipe is different so its the early ones i require.
any help
thanks
keri
Re: pre he injectors
Posted: Mon Nov 24, 2014 9:08 pm
by Brakebuster
the ones i have , HE , have a push on pipe with ferrule that holds the end of the pipe closed onto the pipe, the pipe has ' barbs ' that won't allow the pipe to be pulled off, the fuel rail is the same
the earlier type used a hose clamp around the pipe to the injector ,
hope this helps
