Worrying fuel leak...
Posted: Fri Nov 26, 2021 12:14 pm
Hello there,
I was wondering if someone could give some advice. I have a '93 4.0 manual coupe (so a facelift). It's had a few minor issue (one electrical one that I received some great advice for in the Electrics section). However, last night something developed that I worry may be a little more serious.
Since sorting the starter problem I have been enjoying using the car for a few weeks, but yesterday when returning home I was noticing what was quite a strong fuel smell inside the car and then more so when got outside. It was dark so didn't investigate initially. However, this morning there is fuel on the ground and when the engine is running fuel is spraying down from the rear (approximately where the rear seats are and possibly slightly to the right, but cannot get fully under car).
As it sprays when the engine is running, I am more suspicious of a fuel line rather than tank issue, but certainly not sure. From glancing through the forums it seems like getting replacement parts for fuel lines might not be easy either.
Any thoughts gratefully received!
Thanks,
Tom
Thanks,
Tom
