Water leak
Posted: Sun Jun 11, 2006 10:44 am
by drb100
:( Have just acquired a 1994 4.0 auto with damp underfelt. The floor is rusty in places both front & rear. I belive the problem may be the screen. I was intending to have the screen removed, have some paintwork done & a new screen fitted. I do not think there has been loads of water, the areas are otherwise clean. It would seem that the previous owner was unaware of the problem so did not attempt a remedy.Is this the best way forward? Any suggestions appreciated.
Posted: Sun Jun 11, 2006 6:13 pm
by Brakebuster
Welcome to the JEC forums 8)
it may well be the screen ,
but you may also want to check a place by the bonnet resting bolts on the windscreen scuttle, these have small rubber tops on the bolts a few inches from the windscreen wipers, the reason for this is the scuttle can rot out in this area,
also the aircon system may be leaking into the passenger footwell , its not aircon as such , but condensate from the cooling action
and finally , the heater matrix, make sure the coolant level isnt dropping for this one
hope you get it sorted
Posted: Sun Jun 11, 2006 10:51 pm
by Jon
I've heard that if the aircon condensate drains get blocked, this can be the result. Might be worth checking.
Re: Water leak
Posted: Mon Jun 12, 2006 6:44 pm
by poprivet
I think it more likely that he was very aware of the problem which is why it was for sale :cry:
However, no 12 year old car whatever make or model will be free of problems, so at least you are among friends who will guide you along.
Pop
