rear spoiler
kevinhafner
rear spoiler
Postby kevinhafner » Fri Jun 09, 2006 10:05 pm
Has anyone had a go at removing the rear factory fitted spoiler? I thought it would be easy bot after removing the boot lid trim can only find one nut each side and it won't shift after removing that one bolt. Its on my 93 facelift.
Postby Brakebuster » Sat Jun 10, 2006 12:00 am
dunno about the facelift , but my 1989 coupe had 2 fixings each side,
one was hidden behing panelwork on the bootlid,
but your may well be different
hope it helps
kevinhafner
rear spoiler
Postby kevinhafner » Sun Jun 11, 2006 9:43 pm
thanks, that's what I suspected but couldn't see the other one behind the panelling. Maybe I'll have another try when I get some time.
It will probably need an open ended spanner.
Postby ptjs1 » Tue Jun 13, 2006 9:17 pm
Kevin,
If your spoiler is the very late one, ie NOT the one with a hole for the aerial, then I have an unfitted one waiting in my garage. If it helps, I'll send you some photos of the bolt fixings.
kevinhafner
Postby kevinhafner » Tue Jun 13, 2006 9:50 pm
Hi Paul,
That'll be great if you could. It is the very late one without the hole.
I just need to repaint the underside. My e-mail is kevinhafner@btinternet.com for the photos.
Many thanks,Kevin.
