Keeping the tin worm at bay!!!
Posted: Fri Dec 30, 2005 1:41 am
by jonc3725
Ok the weekend went by and I did'nt get around to it but I've now put together some photo's and area's where the rust preserver will need to be srayed to keep your XJS from rotting in front of you!!!!!
Starting at the front
Front subframe
As we all know this can rot out from the inside without you knowing it.
I drilled two holes into the towers to ensure I could get waxoyl everywhere. There are holes underneath to get to the bulk of the structure
http://static.flickr.com/37/79105834_b0a99c6416.jpg
Also the radiator crossmember can dissapear on you without knowing it. there are plenty of access area's around to get into the lower inner wing structure
http://static.flickr.com/36/79105835_ebeb54db52.jpg
Looking inside the engine bay down both inner wings there are about 5 grommets either side which give access to the upper inner wings and don't forget the shock tower
http://static.flickr.com/40/79105836_ec2e9b6727.jpg
Working outside the engine bay the inner wings can be accessed under the outerwings. remove all stone guards to gain access. This picture shows how corrosion takes place where you can't see it. Bottom of outer wings can be covered from here as well
http://static.flickr.com/43/79105837_78835813ab.jpg
Working in front of the windscreen ensure each void either side of the wiper motor bay is sprayed. can be accessed from the wiper motor bay
http://static.flickr.com/42/79121001_9778676549.jpg
My bonnet was not too good either and treating this part is often forgotten.There are plenty of access holes intp the panelling and also don't forget the fwd voids where the grill sits
http://static.flickr.com/38/79105832_cb535e74bf.jpg
Working back the doors can always do with a good dose of treatment and try and get it behind the safety beam which runs the full length.
Inside the car the are plenty of access points so you can treat front and rear jacking point, radius arm area's.rear seat voids and between inner and outer sills
Front section
http://static.flickr.com/42/79124151_a5483a1139.jpg
rear section including inside bottom of rear wings (nearly always rots here)
http://static.flickr.com/36/79124153_b26f2a05b0.jpg
and middle section where seat sits on crossmember
http://static.flickr.com/43/79110351_630a3c534d.jpg
Working into the boot the whole area could be treated up into the butresses, petrol tank area (obviously my tank is removed so access was easy), rear wheel arches, lower quarter panels even get in around the rear light panels!!.
http://static.flickr.com/36/79105833_48a70fb4e8.jpg
http://static.flickr.com/42/79127499_d061102d44.jpg
Nearing the end :roll:
The bootlid could do with treating the same way as the bonnet and on the rear suspension I treated the radius arm internals and the top inside of the cradle
http://static.flickr.com/36/79129412_5c0a8fc89d.jpg
obviously this was all relatively painless for me as I had cut out all the tin worm and had no interior/boot interior in my way. To strip the car down to this level and spray and rebuild is probably a v long weekends work :? if you use the car daily.
I expect other members will also state area's I've forgotten but it is 0030 in the morning. Hope this helps fellow XJS owners
Posted: Sat Jan 07, 2006 12:22 pm
by ptjs1
Just to wanted to say Thanks very much for the pics! Lots pf people make useful suggestions about rustproofing but it's great to see some practical pictures like this! Tks again!
Posted: Thu Jan 19, 2006 12:26 am
by JulesJag
An excellent resource, well done !
Julian
Posted: Thu Jan 19, 2006 12:34 am
by ng4xjs
Hi Jules. What has happened to jwm? Any ideas?
Nick
Posted: Fri Jan 20, 2006 1:00 am
by JulesJag
Hi Nick,
It seems to be back in action now, but I don't like the changed look as much. Expect I'll get used to it though.
Regards, Julian
P.S I don't seem to be able to log onto it
Posted: Sun Jan 22, 2006 12:59 am
by ng4xjs
Julian
All seems well at JWM but still niffed about loosing most of my history etc. JEC definately begining to take off which is great also.
Nick
Posted: Sun Jan 22, 2006 11:04 pm
by JulesJag
Hi Nick,
I can now logon again to the JWM Forum
Julian
Posted: Sat Mar 25, 2006 11:17 pm
by Telsmoneypit
Jon, thanks for a superb post and informative pics. Lets hope this doesn't disappear like the JWM stuff did! :roll:
Good stuff
Terry
