I am about to fit missing boot badges to my facelift XJS. Is there a "right" position or is it fairly approximate? Looks like I'll only get one go and these are pigging expensive for what they are!
Thanks in advance...
Boot badge question
John Lodge
S3 Sovereign in Antelope and facelift XJS 4.0 Goodwood Green
Re: Boot badge question
My suggestion would be to find a fellow member with a similar car and take some measurements. At the factory they probably had a template to get them straight and, as you say, you only get one go!
Trial fit with Blutak first then stand back and have a look.
UPDATE - found the page in the workshop manualI am about to fit missing boot badges to my facelift XJS. Is there a "right" position or is it fairly approximate? Looks like I'll only get one go and these are pigging expensive for what they are!
There is a right position.
---update---
I made cardboard masks that sit on top of the chrome finisher and butt to the left and right-hand lid edges; then you carefully position the badges to rest on the top edge of the cardboard, and press home.
It's in the Workshop manual Volume 4 Body Repair section 77 page 18.
In essence, the line across the bottom of the V12 is 22mm above the finisher and 34mm from the RH edge.
The X of the XJS is also 22mm up, but the S is 21.5mm up (that's 'cos rounded edges need to exceed the line to look "right") and the left edge of the XJS is 145mm from the right edge of the V12. If you're not a V12, the XJS is placed 34mm from the RH edge.
The Jaguar is 34mm from the LH edge, and 22mm up.
Obviously, you have to ignore the descender on the J in both Jaguar and XJS.
Thanks for the help all
I *think* I’ve got them positioned correctly. They look ok, which is always reassuring.
John Lodge
DavidCosham
Where is the best place to source replacement boot badges for a 1996 celebration convertiable? I assume these should be silver not gold. Or would anyone advise getting existing badges replated? Thanks.
David
New owner of 1996 XJS Celebration convertible
Looking forward to meeting and sharing interest in these wonderful cars
Hi David - these badges are still available from Jaguar.
https://www.jaguarclassicparts.com/uk/j ... onvertible
Interestingly the VIN codes suggest they should be gold. Mine look silver but I think that is only because the colour has worn off after all those years of washing and polishing. AFAIK the wheel centres are also gold (on black).I assume these should be silver not gold
Having said that the colour of the paintwork will be an influencing factor.
Robbie
Daimler Sovereign S1 4.2 1971
Plastic gold badges were an option and often fitted to US cars. Most UK Celebrations came with plastic chrome (silver) badges. And yes, the gold ones just fade to silver over time anyway!
