Chrome window surround
Sonic!!!!!
Postby Sonic!!!!! » Thu May 17, 2018 6:31 pm
Looking to renew the trim pieces between the chrome and scuttle on a facelift coupe. Any pointers or things to look out for. Also can you gat a Haynes manual or similar for the facelift Jaguar 4.0
Re: Chrome window surround
Postby davidr » Thu May 17, 2018 8:55 pm
Hi - not quite sure which piece you are trying to replace - can you post a photo?
The only Haynes manual for the XJS is for the early V12 and won't be much use. Try the Club shop for a Repair Operation Manual on CD.
Sonic!!!!!
Postby Sonic!!!!! » Fri May 18, 2018 9:41 am
It is the rubber/plastic piece between the chrome windscreen surround and the scuttle. I believe it is to prevent the chrome trim rubbing the paint.
Postby ptjs1 » Fri May 18, 2018 10:48 am
Sonic!!!!!
It's part number BEC17446 and is NLA. You'll have to find 2 x secondhand bits or else make some from some rubber / plastic.
As regards workshop manuals, there's been a problem for some years on the production of the CDRoms. So, have a look through ebay for a use one. The part number for a 4 litre XJS CDRom is JHM1143.
Pul
Tintin
Postby Tintin » Fri May 18, 2018 3:13 pm
I had two lengths fitted when I replaced my w/screen in 2016 and AFAIK BEC17446 is still available (as an aftermarket suppliers part) - it is listed with SNGB and DMG.
PTJS1 may have more up to date info than I but it would be worth checking with the usual suppliers before resorting to used/made up parts.
Good luck.
Robbie
Daimler Sovereign S1 4.2 1971
Sonic!!!!!
Postby Sonic!!!!! » Thu May 31, 2018 3:58 pm
Thanks all
The part is still available from SNG
cmagnusreay535
Postby cmagnusreay535 » Sat May 30, 2020 1:20 pm
Thanks for this - I've been looking for this part for a year but couldn't find it.
Armed with the part code I've ordered it from Barratt's easily.
Magnus
