Can I use mk2 wire wheels on an XJS?
vipervisual
Postby vipervisual » Thu Dec 07, 2017 4:01 am
I'm thinking if buying a set of bolt on mk2 wire wheels. Can I use them on my XJS?
Is there anything else i need to consider? Do they creak???? Will they take the weight of the XJS??
Re: Can I use mk2 wire wheels on an XJS?
Postby davidr » Thu Dec 07, 2017 11:55 am
I don't think the bolt pattern, offset etc will work. The XJS is a big heavy car and I'm not sure those wire wheels will be rated sufficiently.
There are wire wheel conversion sets that will fit and are properly rated - they were popular in the States.
Perhaps try Dayton?
vipervisual
Postby vipervisual » Thu Dec 07, 2017 9:39 pm
I think your right!
Thank you.... Drayton will look them up. Or I may just go with the Lattice version thats classy too :)
vipervisual
Postby vipervisual » Thu Dec 07, 2017 9:40 pm
https://www.ebay.co.uk/itm/Bolt-On-Set- ... 1438.l2649
These are the ones I was going to get.
And yes the XJS is heavy!
Postby ptjs1 » Fri Dec 08, 2017 12:28 am
vipervisual,
I'd really suggest you got for the lattice if you're thinking of changing wheels. The bolt-on Dayton wires were just bought by owners in the US market. Quite a personal taste IMO. Not an option specified by Jaguar for UK cars.
If you're going for lattice wheels for a pre-facelift car, you might consider going for the facelift 16" lattice wheels as it gives a much easier modern tyre choice.
