rusty rear drivers buttress replacement
Posted: Fri Aug 31, 2007 8:20 pm
i will attempt to show you how i rebuilt the drivers side rear buttress that had severely rotted,
first looks make you think this is one pressed piece of steel you would be wrong, the rear buttress is made of at least four different panels, welded together at the factory , this includes the section from the roof, the boot gutter, and the inner side is made of three sections welded and lead filled to make them look as one
firstly , the rust, the area around the aerial hole had completely rotted through , and the section up by the rear window one inch up from the boot gutter had also holed, this is due to the welded sections having an internal lip ( go ahead, have a feel in ur own car ) and this traps condensation, and rots from the inside out, so its always ten times worse than that small bubble you can see on the outside
http://www.talkphotography.co.uk/galler ... edium_.jpg
i obtained two separate sections from different donor cars, the one was the whole rear buttress section from the back window to the rear light, the other was a small square section around the aerial hole
knowing what metal i had, i cut out all the rot so i could fit the repair sections
http://www.talkphotography.co.uk/galler ... edium_.JPG
repair sections were carefully cut to size and test fitted prior to welding , the edges were ' joggled ' to give an overlap of metal to weld in places
http://www.talkphotography.co.uk/galler ... dium_1.JPG
continued on page two,
