29 years of the dreaded tin worm
Mr.Ian
Postby Mr.Ian » Fri Jul 13, 2007 10:03 pm
dhdove
Postby dhdove » Sat Jul 14, 2007 9:57 am
Mr Ian
I edited out all the depressing bits from my previous post (about 95% of it) but having seen these pictures I feel I must now express my concern over the structural integrity of this car.
Are you 100% confident that you can restore it and replace all the original strength to the chassis?
Whilst it may well drive ok what will it be like if it gets sideswiped by a truck :?:
I really don't want to bring a negative note to your restoration project but I believe there could be a real safety issue here........... :shock:
I don't know if it's still for sale but one of the specialists (I think Pop pointed it out) was selling a new unused shell a couple of weeks ago - perhaps that's the way to go?
DH Dove
XJS Bulletin Board Moderator
Mr.Ian
Postby Mr.Ian » Sat Jul 14, 2007 8:39 pm
Boot floor was taken out on the spot weld panel joint anyway, the only real concern is the joint on the chassis in the boot, but if you notice the upper and lower sections are different lengths to give a stepped joint and fully seam welded would be more than strong enough, but also i'm putting a strap across and covering the joint fully to give support (i'll post pics when done), the metal going in is a boot floor/rear valance assy from another XJS that had been written off due to a front end smash.
I can understand a concern with being side swipped by a truck but what would you say was stronger, a rusted chassis or a seam welded strapped joint on a non rusty one?
Whilst on the subject of structure the top of the original rear chassis wasn't even welded to the under rear seat area from new, yes there were the spot weld marks in both panels but they were not touching (and they hadn't popped apart). All this area is now seam welded and far stronger than when the car was new.
I'm restoring this car to keep, however if I did ever sell it I certainly wouldn't hide all the work that has been done and would show all repairs with the pictures taken during it's build.
Maybe i'll leave posting the pics of my 4-5 years of work, I just thought people might be interested.
:cry:
poprivet
Postby poprivet » Sat Jul 14, 2007 9:05 pm
Well for one I'm interested. Brake-Buster here has been going through a similar experience, the rebuild is as much of the hobby as the driving. True no-one would willingly take on a project like that purely for commercial gain but thats not what its about is it?
I hope you do post more of the problems and solutions, the rest of us can learn a lot I'm sure.
Pop
Postby ptjs1 » Sat Jul 14, 2007 11:48 pm
Mr.Ian,
Great to have your contributions. More pics and stories of the misery of your rusty car will be hugely welcomed as it will:
a. make me feel a bit smug about my own rust-free (I think!) car
b. give me hope that if (when) mine does deteriorate, then miracles are possible!
Bring it on!
dhdove
Postby dhdove » Sun Jul 15, 2007 9:40 am
Mr Ian
None Intended :!:
It was never my intention to say or even imply that you were not a most welcome new member to the Forum and I do not believe that I have done so. I'm sorry if you have interpreted my posts in that way.
Your original post was entitled "70's XJ-S too bad to rebuild?" and you thought that members might say that the car should have been scrapped.
My concern is this.......having seen your photos and read the description of the car there doesn't seem to be much if any of those chassis areas that give the bodyshell it's structural integrity that have not been affected, some seriously, by rot. I agree that anything can be repaired but I do have a concern where there is little left other than repairs. This is only my opinion.
With regard to selling the car and hiding any work done I have not made any reference to this, nor would I dream of doing so.
I too, wish you luck with your project and look forward to seeing other areas of the car that need to be repaired and the work you carry out.
NB Sorry, I have no idea where you should mount the rear trailing arm. :(
Pace
DH Dove
Mr.Ian
Re: 29 years of the dreaded tin worm
Postby Mr.Ian » Sun Jul 15, 2007 8:21 pm
No your posts didn't make me feel unwelcome, they just made me feel the work I was doing was 'too deep' for most on this forum as it were.
As for structural integrity it's the relation of all panels I feel add to this main others being the inner/outer sills, A B C posts and roof.
People are so frightned when they have the MOT man saying 'well there's lot of rust on the chassis, it'll need welding up'. But at the end of the day the chassis legs are a seperate replcement part in the parts book. If I had been able to get or afford one at the time I was doing the jacking points I would've.
No I know you didn't mention selling the car I just wanted to state that I was restoring her to keep. Yes I could've and maybe should've got a better one but I wanted the earlier black bumper type and felt they'd all need a lot of work (didn't think it'd be this much though), I also felt that it'd be a 'quest' as it were to get her sorted.
As for getting a new bodyshell for her, that's what i'd call the easy way out as it's no longer a restoration as the original body is scrapped.
Postby Brakebuster » Sun Jul 15, 2007 11:15 pm
i have replied to the other thread, and didnt realise that you were so far into the project,
as for the condition of your particular car, i dont think i have seen one quite so bad , it must have been filled with water for quite some time to have that much rust ,
the 'new' body shells for sale on ebay are, as stated ' brand new' original Jaguar stock, but they are however of the latest ( 92-96 ) body shells, and are designed to take the later AJ16 engine and have many different mounting points for different items, so for the vehicle you want to restore they would have been no point in having one, even if they are only £1700
as for your repairs, though not to original spec, they look fine and strong, and as you say , they wernt put together all that well to start with , i would however recommend putting her on a jig to make sure she is straight and true before any other works are done ( painting and finishing )
i am always keen to see pictures of other projects, as some have said, i am three years into my own rebuild, but nothing on your scale, pictures can be seen in the bodywork section of the forum, usually with the word ' rust ' in the title, lol
Mr.Ian
Postby Mr.Ian » Mon Jul 16, 2007 12:34 am
Hi, yes I think it must be the worst condition XJ-S that is fighting to be saved.
It's far worse than the one the JEC followed the rebuild of a few years ago, but reading that gave me the confidence to tackle such a large resto project.
I'm determined not to let her go to the scrapyard in the sky.
Quite a lot of work has been done now.
I.E:- rear jacking points/chassis, heelboards / inner sills / floorpans / front jacking points. Rear suspension/diff cage has been removed - stripped and rebuilt with new discs/pads/shocks/seals.
Current area being done is the boot floor/rear valance area.
1978 XJ-S V12 Auto - Under Restoration
Mr.Ian
Postby Mr.Ian » Tue Jul 17, 2007 12:45 am
Just a few photos' of the replacement boot floor valance assy that's going to be fitted when I get round to it. I could not belive how clean this was the rusty looking marks are just staining and wipe off.
Even looking into the closed sections it is all spotless.
http://farm2.static.flickr.com/1241/831 ... 08e6_m.jpg
http://farm2.static.flickr.com/1056/831 ... 98c7_m.jpg
http://farm2.static.flickr.com/1315/831 ... ee4d_m.jpg
I can't wait to get this fitted, then I can get her off the 4 stands and 6 - 8 jacks put her back on her wheels n get that luvverly V12 ticking over again (well V11 as she's got a duff injector that only appears to work on a Friday night after 11pm) :lol:
Postby Brakebuster » Tue Jul 17, 2007 10:20 pm
cool
my boot looks like that, and as such i need do no work at all regarding any rust,
the drivers side rear vallance has gone, but show me an XJS that hasnt , lol ,
my floor was also in great condition, just a repair to both seatbelt mounts on the floor, and an eight inch section agianst the trans tunnel on the passenger side, i then fully rustprofed the floor, and fully covered in sound deadening dynamatt foil from toe boards to rear wheels ,
http://www.talkphotography.co.uk/galler ... Small_.JPG
Postby Brakebuster » Tue Jul 17, 2007 10:33 pm
Mr.Ian
Postby Mr.Ian » Wed Jul 18, 2007 12:02 am
Nice pics and nice repairs there, very strange that your car has rust damage to the full 'A' post pillar area yet mine was just the bottom 2-3cm (has yours got a sunroof ?), also your headlamp mounting area rust compared to my far worse overall car has no rust there whatsoever.
Rear wings are about the same although previous repairer/botcher has fitted a non gen arch repair and so the original wing has been cut off at the body line to have it welded on (very badly and with distortion). But luckily I have a spare s/h rear wing in far better condition.
Also I notice your seat belts mount through the floor on the kickup? whereas mine are straight into the inner sill
Funny little differences between models / years
Mr.Ian
Postby Mr.Ian » Wed Jul 18, 2007 12:08 am
Now i've read you little signature I notice you have got a sunroof. :oops:
Come on Ian wakey wakey :lol:
Postby Brakebuster » Wed Jul 18, 2007 3:32 pm
yes , the car has a sunroof :wink:
and its an original Jaguar factory fitted one,
but it had no bearing on the rust of the drivers A pillar , as the drain tubes work perfectly and the whole inside of the car was always dry , thats why the floors and boot are in great shape,
the seatbelt points rust from underneath , as debris gets trapped between the strengthening plate and floor section, and rots it out, i had to carefully remove the rear seat support post, cut out the rot, make a new strengthening plate, weld that in, then patch in a new section of floor, then weld the seat post back in, quite a lengthy job, on both sides ,
i think my car must have been parked in some sort of car port for most of its life, and got all the weather as the front had almost rotted off , as can be seen in the pics, both doors, both wings, both inner arch box sections, sill front ends ,both headlight rims and bowls and the front cross member had all rotted,as well as the drivers A pillar , and were fully replaced with new panels, basically , everything painted red in the above picture is new metal apart from the inner engine bay panel ,
http://www.talkphotography.co.uk/galler ... edium_.jpg
http://www.talkphotography.co.uk/galler ... edium_.JPG
now with all new front lower scuttle panels etc, good used wings and perfect used doors,
BB ( good fun this , aint it , lol )
bespoke seatbelt mount , the old one is on the right, lol
Users browsing this forum: No registered users and 34 guests
