The black plastic front air-dam of my 1992 (facelift) convertible has had the common kerb-quarrel and has broken clean in two vertically 2 thirds of the way across its length. The two parts remain attached to the car, but are a bit loose and the half-inch wide split looks tatty.
Don't seem to be able to get hold of what, in theory at least, looks like a large yet simple piece of moulded plastic.
Do any experts know:
a) if this item can be sourced at reasonable cost (nothing on e-bay).
b) whether it is feasible to have a serviceable repair done to solidly re-fasten the broken sections together without using unsightly fishplates etc.???????
Black Plastic Air-dam Broken (1992 facelift)
keithmervyn
- MARKPEARSON
Keith,
As you've probably realised, the spoiler itself isn't available from Jaguar at the moment although the undertray is. So I guess you've got two options - buy a second-hand one or else fix your own. As a suggestion, you may find that you can get good results going to one of the guys who repair motorbike plastic fairings. They can do a fantastic job of creating invisible repairs. Or else, someone like Sprayaway, which is a franchise of companies who do minor repairs including plastic welding may be worth considering.
Good Luck
Good Luck
keithmervyn
Thanks for advice on broken front spoiler. For the record, a new Jaguar spoiler costs around £150, IF you can find anybody with one in stock. I couldn't, but I did eventually find a very good one on e-bay, which I got for £46 + carriage. Fitting is easy.
Problem solved, but I did then repair my broken spoiler by temporarily fish-plating it together, then using high-quality body repair material, with glass-fibre matting and metal mesh, on both sides of the break, before removing the fish-plates and matting over where they were. This all bonded perfectly and the break is now very strong. Cleaned it up, rubbed it down and sprayed the whole matt-black. Now I have a spare spoiler for when the next kerb gets in the way !!
Keith MR
