Rear number plate lamps and lenses
Andover59
Postby Andover59 » Sat Dec 28, 2013 6:33 pm
Hi all,
If its not too much of a liberty to ask could someone who has a manual take a snapshot of the section that covers removal of these as I dont seem able to get to one pair of the screws that hold this in place. At first glance it looks simple but.....
Help sincerely appreciated,
roy
1991 Jaguar XJ-S V12 5.3 Convertible
PaulGover
Re: Rear number plate lamps and lenses
Postby PaulGover » Tue Jan 07, 2014 2:58 pm
Hi all,
roy
There's no rocket science, BUT they only fit in one way round, as the holes are just a little off-centre.
The exact words from the manual:
"Disconnect the battery.
Undo and remove the lamp securing screws.
Displace assembly from aperture.
Disconnect wires from lamp.
To fit a new lens is a reversal of the removal procedure."
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
Andover59
Postby Andover59 » Tue Jan 07, 2014 6:52 pm
Hi all,
roy
Hi Paul and thanks,
You seem to describe the two screw lens which I have located details for but what I seem to have however is a four screw arrangement lens, (why it couldnt just be like the reverse light lens I dont know !!). Any how after several searches it seems I need to remove the tail gate trim to get to two of these so problem almost solved, (I have yet to get round to doing the actual job itself :oops: ).
Roy
