Drifting around at high speed
AlexWhittingham
I have a 1981 HE which is under restoration. It always used to get light around the front end at high speed, 120mph+. Is this a characteristic of later cars as well? If not, I wonder if fitting spoilers from the facelift model would improve the downforce on my car? I would appreciate any views, particularly from the racing fraternity.
Is the standard spoiler fitted? The car would go light at the front without it.
AlexWhittingham
The standard spoiler for an HE is fitted, a little black rubber thing.
Not any help, but even with the front spoiler missing (I hit a rabbit), my 3.6l ('86) doesn't have problems staying on the road/track at 130-140 (indicated 145).
How "bouncy" is your front-end (ie what shape are the springs and shocks in)?
Sheepy
Sheepy
'66 MGB Roadster
'66 MGB Roadster
just a thought... what's the ride height like at the rear? If the springs are weak and sagging that'll put the nose up a bit.
XJ-S 3.6 230k miles +
These cars have a natural tendency for being nose heavy and even with a poorly performing rear end I doubt this would fully explain your particular problem. My guess would be front spoiler related although you do appear to have discounted this. It is possible that the front shock absorbers are past their best which could also contribute to the problem. Fairly straightforward but you will need to remove to test. Even if they are okay you can replace the top bushes and at least dispose of that annoying rattle/knock you were probably experiencing.
Hope this helps
Nick
Hope this helps
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
