LED headlight coding?
Moderators:jBlackwell, mike020150
garagedood
2017 3.0s diesel. I have a ‘ dipped beam fault’ message appearing. My JLR specific icarsoft scanner tells me B1D64 - ‘motor operation, malfunction of left actuator’. I am working my way through the list of anecdotal fixes found on the net and elsewhere but am kind of resigned on having to either repair ( meaning dismantle and repair/replace an internal component) or replace with new or used. If I do have to replace the headlight will it need to be coded to the car? I would have expected it would but one seller claims ‘ plug and play’. Anyone know the truth???
Re: LED headlight coding?
I don’t think headlights need coding, but happy to be corrected…
XF Sportbrake 2020 / XK8 1998
Sadly, here's the appropriate phrase from the workshop manual for LED headlamp replacement, "Using the Jaguar Land Rover (JLR) approved diagnostic equipment, configure the Headlamp Control Module A (HCM) for left and Headlamp Control Module B (HCMB) for right headlamp replacement."
Mike.
