Auto Window open close feature
Posted: Tue Aug 06, 2024 2:18 pm
by dyrham663
My Brother in law showed me a 'trick' with his Skoda .... press the unlock button on the fob and keep it pressed. It unlocks then a few seconds later all the windows open. Also, press the lock button and keep it pressed, the car locks and a few seconds later all the windows close..
Im not sure if this is a fairly common feature on remote lock / unlock fobs but I never knew about it.
Anyway, tried it on my E-pace and it works. Tried it on the F-pace and ... it doesnt work! Maybe its a setting somewhere?
Steve
Re: Auto Window open close feature
Posted: Tue Aug 06, 2024 3:05 pm
by drjohnehunt100
Works on my F-TYPE as well
Posted: Wed Aug 07, 2024 10:31 am
by mike020150
In settings, you need to tick the box which from memory is called, 'Global opening/closing'. Mike.
Posted: Wed Aug 07, 2024 7:03 pm
by Marineng
I am always suprised how effective this Global opening feature is. In hot weather, push the button on the key fob while approaching the car, and within a few seconds the hot air inside the vehicle is replaced with cooler air from outside the car.
Global opening and Global closing are two different settings on my I-Pace SE. These can be found under the 'Convenience' setting on the dashboard menu.
Kind regards
Posted: Wed Aug 14, 2024 9:52 am
by dyrham663
Yes, one tick from each box. Also changed to unlock all doors, not just drivers when opening. Lots of interesting settings to fiddle with actually!
Steve
