Auto Window open close feature
Moderators:jBlackwell, mike020150
dyrham663
Postby dyrham663 » Tue Aug 06, 2024 2:18 pm
My Brother in law showed me a 'trick' with his Skoda .... press the unlock button on the fob and keep it pressed. It unlocks then a few seconds later all the windows open. Also, press the lock button and keep it pressed, the car locks and a few seconds later all the windows close..
Im not sure if this is a fairly common feature on remote lock / unlock fobs but I never knew about it.
Anyway, tried it on my E-pace and it works. Tried it on the F-pace and ... it doesnt work! Maybe its a setting somewhere?
Steve
XK (150) 2006, F Pace Chequered Flag Petrol 2019
drjohnehunt100
Re: Auto Window open close feature
Postby drjohnehunt100 » Tue Aug 06, 2024 3:05 pm
Works on my F-TYPE as well
Postby mike020150 » Wed Aug 07, 2024 10:31 am
In settings, you need to tick the box which from memory is called, 'Global opening/closing'. Mike.
Marineng
Postby Marineng » Wed Aug 07, 2024 7:03 pm
I am always suprised how effective this Global opening feature is. In hot weather, push the button on the key fob while approaching the car, and within a few seconds the hot air inside the vehicle is replaced with cooler air from outside the car.
Global opening and Global closing are two different settings on my I-Pace SE. These can be found under the 'Convenience' setting on the dashboard menu.
Kind regards
dyrham663
Postby dyrham663 » Wed Aug 14, 2024 9:52 am
Yes, one tick from each box. Also changed to unlock all doors, not just drivers when opening. Lots of interesting settings to fiddle with actually!
Steve
