Handbrake pad thickness - outboard brakes
Posted: Tue Apr 09, 2019 12:30 pm
by almcl
Does anyone have an official source for the minimum handbrake pad thickness on the outborad (drumbrake style) handbrake pads?
The service schedule calls for a check of the thickness (which means removing the disc!) but I can't find a figure in either the CD or my paper copy of the Service Manual.
Re: Handbrake pad thickness - outboard brakes
Posted: Tue Apr 09, 2019 1:10 pm
by davidr
I'm not sure about the minimum thickness question but I would recommend going with your guts. If you think they look a bit skinny then change them. A quick eBay search suggests Mintex or Delphi can be bought for less than £20 a set.
Posted: Tue Apr 09, 2019 4:41 pm
by almcl
Thanks, David.
As you say (and having got the disc off anyway) it might be as well to change them. There's 3 mm of pad material remaining and 3 mm of backing plate.
I just saw that Jaguar Classic parts want a whopping £363 for a set and although Barratts are only a tenth of this at £34 and another online source quotes £12 but then offers two different sizes...
Posted: Tue Apr 09, 2019 7:07 pm
by ptjs1
Al,
As youve seen, the JCP price is ridicous, apparently because of the one supplier that they use for these shoes.
Check carefully before you buy. This is an example of where many of the brand suppliers have got the wrong spec for the early outboard brake shoes. I have suffered from this! Measure your shoes carefully, then purchase accordingly. There are two different sizes and most suppliers quote the wrong ones!
The good news is that you'll never have to do the job again as the shoes seem to last 60k+ miles!
Posted: Tue Apr 09, 2019 7:14 pm
by almcl
Thanks, Paul!
They were replaced a while ago during a service, and so if I can wade through the mountain of garage receipts that is my XJS history file, it might be worth checking how many miles that was.
Posted: Fri Apr 12, 2019 7:56 am
by NATONEIL
The hand brake shoes should not wear. Apart from the MOT test to check that the handbrake works as an emergency brake it never needs to be used when the wheels are rotating. If you are getting wear then the shoes might be dragging.
