ABS light occasionally on
Posted: Sun May 06, 2018 9:54 pm
by davidr
The ABS light on my 1996 Celebration comes on occasionally. As the car has an OBDII socket I plugged my iCarsoft 930 in and had a look. (Although the iCarsoft doesn't list the XJS, I tell it that the car is an X300 and I get access to a number of readouts such as engine, gearbox and ABS). It told me that the front right wheel sensor was faulty. As the fault comes and goes I thought I'd check the connections and test the resistance.
The connector is on the inner wing as below.
Opening up the connector and looking at the terminals they looked OK but I thought I'd still put some electrical cleaner in there and blow it through with the airline.
And then I put the multimeter on the 2 connections to measure the resistance of the sensor.
As you can see, about 1.1k ohms. That led me to wondering what it should be! Does anyone know?
Re: ABS light occasionally on
Posted: Mon May 07, 2018 9:01 pm
by davidr
I thought I'd test the left side wheel sensor to see how it compared to the right one.
So 1096 ohms right and 1101ohms left. The ABS light stayed off today so here's hoping! :D
