On the basis that the 95 XJS had outboard rear discs and my '92 4.0 has inboard (new to me except for a vague recollection that teh ALFA 75 had inboard), is it possible to convert mine to outboard?
Aaron
inboard outboard
car garage includes BMW Mini Cooper S, and BMW E39 530i and now XJS '92 4.0 FHC. Soon to add Subaru Legacy Spec B estate. Not sure which one of above to go.
inboard outboard
It is possible, but given the hassle (handbrake cable, plumbing, wishbones etc) what do you actually gain? True the brake pads are easier to change, but how often do you do that job?
Al McL
inboard outboard
I did mine using XJ81 (XJ40) parts, the hub, brakes, drive shaft.
Then made some 0.8mm wall tube spacers for the outer pivot pins (they went from imperial to metric), then made a short arm and pivot to conect the xjs handbrake cable to the xj40 rear cable parts. Then make a spacer for the drive shaft to go where the inboard disk used to be.
Its quite a fair amount of work.
On a road car its probably pointless!
Re: inboard outboard
I agree, why bother. True outboard a great deal easier but a whole lot of hassle to change over.
Nick
Nick
That's a true thread from the dead, 8 years!
I don't think Ralph (Hosier77) is a member these days, I liked his racing XJ-S exploits and met him a couple of times, clever chap
Just keeping the thread alive.
