handbrake pad replacement
Johnscotty22
Postby Johnscotty22 » Thu Oct 11, 2018 11:46 pm
Hi there, I'm about to replace the rear pads and handbrake pads..Any hints or advice??
Scott
davidr
Re: handbrake pad replacement
Postby davidr » Fri Oct 12, 2018 8:39 am
It would help us to give you a more relevant answer if you put the year and variant of your car in your question. In this instance it will help us to know if you have inboard or outboard brakes for example.
Maybe add it as a signature which will put it at the bottom of your posts?
David
ng4xjs
Postby ng4xjs » Mon Oct 15, 2018 7:35 pm
I think this is one of those occasions when we can agree that "outboard" wins hands down :D
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
Johnscotty22
Postby Johnscotty22 » Wed Oct 24, 2018 10:44 pm
Apologies, 1989 v12 convertible...chickened out and got a local mechanic to do it.. got the car back fine but handbrake lights on the dash are acting up..they come on when its engaged but glow when its disengaged and when I press the brakes they go out, but lamp warning light comes on.. brake lights are working fine. Any ideas?
:o
davidr
Postby davidr » Thu Oct 25, 2018 5:43 am
The switch is in the handbrake lever mechanism. I would check that the contacts are OK and that the cable is adjusted properly. It may be that it is slightly too tight so doesn't quite fully release. Was the mechanic who did the work familiar with the Jaguar inboard handbrake set up? It is a little peculiar!
NATONEIL
Postby NATONEIL » Thu Oct 25, 2018 10:36 am
This is unlikely to be a mechanical problem and more likely to be a switch or wiring issue. Check the switch and its wiring first and look for broken insulation and short circuits. If there are no problems there, then you probably have a wiring problem in the brake light circuits
Neil
Suffolk SS100 Jaguar
davidr
Postby davidr » Thu Oct 25, 2018 12:44 pm
Is it the handbrake warning light or the footbrake warning light that's coming on?
Johnscotty22
Postby Johnscotty22 » Thu Oct 25, 2018 11:01 pm
Hi, The handbrake was adjusted too tight so wound it back. The lights go on when the hand brake is on but when I take it off they glow slightly. I think its the handbrake lights not the foot brake, the "p" red light and the regular amber light. when I press the foot brake the "p" and amber go out but the amber light with the x on it comes on full.. it was perfect when I gave it to the mechanic.. Unfortunately they have never worked on an xjs before, no expertise where I live...Seems to be more things wrong with the car now :( its very low mileage and pristine..just asked them to do a few recommissioning bits and pieces as has only done 1100 miles in last 13 years..very frustrating..I have an xk120 that I do my own work to, just the xjs was bit daunting for me!!
davidr
Postby davidr » Fri Oct 26, 2018 12:31 pm
Would you be able to post a couple of pictures of your dashboard with the lights in their various states?
PaulGover
Postby PaulGover » Thu Nov 01, 2018 2:01 pm
That's usually neither the problem nor the cure. The XJS inboard rear handbrake are "self adjusting". If they appear to need slackening off, the mechanism isn't working correctly, and will rapidly "readjust" back to the same point.
The way it works is each time you operate the handbrake through its full range of travel, a ratchet in the brake mechanism clicks over, removing a bit of the slack. When you get less than a full travel because the pads have seated on the disks, the movement is insufficient to click over the rachet, so it takes no more slack out (until the next time the pads have worn enough, which in normal use for a handbrake is virtually never). It's almost never right to adjust the brake cable in the XJS.
The ratchet works against the phosphor bronze springs (two long fingers attached to a cross piece and held in place by the handbrake caliper mounting/pivot bolts). The failure mode is that the ends of one or both of the fingers aren't seated in the little holes in the pad carriers, allowing the pad carriers to sit at the wrong angle. This allows the ratchet to keep clicking over, causing rapid brake pad wear. It's quite easy to wear through the pad down into the metal carrier, causing damage to the brake disk. And the brakes are ineffective. Alternatively, the pads stuck to the disks over the winter, or the user left the handbrake on while driving, and one or both of the pads pulled off their backing.
To fix it you need someone who's seen it before, has a decent car lift, lots of light, and thin, nimble hands. The cursed phosphor bronze springs are on top of the brakes, hidden by all the drive shafts, disks, brakes and suspension. You can do it using jacks or axle stands, but it's hard - it usually takes me about a day of cursing to get the fiddly little end bits of the fingers in the tiny holes.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
