A/C Compressor clutch
grantedwish
Postby grantedwish » Fri Jul 20, 2012 7:29 pm
Has anyone changed a clutch assembly on a GM Harrison type compressor? and if so how?
almcl
Re: A/C Compressor clutch
Postby almcl » Sat Jul 21, 2012 7:23 am
Instructions are given in the Jaguar repair manual. They run to about 3 pages. You need three special tools, plus the parts and the consensus is that experienced mechanics have about a 30% chance of success.
Good luck!
Al McL
dhdove
Postby dhdove » Sat Jul 21, 2012 4:49 pm
Fit new exchange compressor?
TonyS
XJS Bulletin Board Moderator
poprivet
Postby poprivet » Sun Jul 22, 2012 7:42 am
Before committing to replacement, are you sure its the clutch that's failed?
Low refrigerant gas will interrupt the circuit as will poor connections. If you pull the two connectors off and zap it with 12V you will see the magnet pulling the plate if its working. Sometimes the plate distance can be excessive and the magnet can't pull it.
grantedwish
Postby grantedwish » Sun Jul 22, 2012 3:30 pm
The clutch plate mount has fatigued and broken. However a welder friend says that he can weld it like new so think all is ok! Thanks for reply s.
