I've found a replacement but am having a hell of a job replacing it!
Has anybody ever done this or can give me any advice?
You can easily remove the front screw through the hole left by removing the instrument panel,but the screw at the back is impossible to see let alone remove and refit ,due to a reinforcing butress welded to the bulkhead right next to the motor.
Anyone done it or know any tricks?
Managed to get it out now with a bit of brute force,by bending the bracket a bit.Was worth while as the were a couple of teeth missing on the little plastic gears.
Trying to get it back now! Don't ever want to do this again!!
