Air con pump overhaul.
Posted: Thu May 28, 2009 10:45 am
Hello, I have just bought an air con pump overhaul kit from JDHT Ltd, for my 1996 Celebration, it consists of a seal kit and 2 " O " rings, for a grand total of £43.46.
The seal kit is two special metal/rubber round units @ £28.89 + vat and the two rubber seals were £4.56 + vat and £5 P+P +vat.
At the time of writing I have not fitted/ tried to fit the parts. I hope it is not too difficult a task and just a case of dismantle carefully and then replace and reassemble. The pump is to be removed from the car for the surgery and it looks like a bit of a task as there is not much space in the engine bay.
I will take some photos as I go and let you know how it goes.
I needed the kit as there was a discharge from the front of the pump which sprayed onto the inner wing, the coloured dye was a dead giveaway for where it came from.
