Air con odd problem. Facelift 4l 1992
Lodgie
Postby Lodgie » Wed Jul 03, 2019 2:21 pm
Aircon air temperature is nice and cold but it's only coming through very slowly regardless of the fan speed. The fans sound like they are working just fine, the speed is variable but the volume of air getting to the vents is very low. Any clues on where to start looking. Local garage diagnosed "lazy fans" but I this doesn't seem right.
All working OK before the winter lay-up.
All hints and tips greatfully received.
John
John Lodge
S3 Sovereign in Antelope and facelift XJS 4.0 Goodwood Green
poprivet
Re: Air con odd problem. Facelift 4l 1992
Postby poprivet » Wed Jul 03, 2019 3:44 pm
Have a read of the guide posted by KWE You may be able to narrow down where the problem lies.
http://www.kwecars.com/technical/jaguar ... s-and-use/
Could well be stuck flaps, they like being excercised regularly,
Al
Postby davidr » Wed Jul 03, 2019 10:16 pm
May also be that only one fan is working?
ng4xjs
Postby ng4xjs » Fri Jul 05, 2019 9:01 pm
I'd go stuck flaps. Thump the top of the dash in the area immediately above the face vents (obviously avoiding damaging any part of your person) :D
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
Lodgie
Postby Lodgie » Sun Jul 14, 2019 4:44 pm
Hi all,
Thanks for that people , I'll go for the wack on the dash first to see if that frees the vent otherwise full KWE fix … Both fans working well.
John Lodge
