Aircon compressor
Dave
Aircon compressor
Postby Dave » Mon Aug 06, 2007 11:06 pm
Yesterday I noticed that the aircon temperature wasn't as cold as usual. Then there was a slight rubber burning smell. Then a squealing of rubber. Then a smouldering broken rubber belt in my rear view mirror bouncing along the M3.
The belt to the aircon compressor had come off.
Either I'm lucky and it just needs a new belt, or it only broke 'cos something seized horribly.
The question is; should I be able to turn the compressor pulley wheel by hand (now the belt's not there)? I can't, but they are quite meaty compressors, so maybe that's normal.
Also, any good aircon specialists in the Southampton area?
Thanks.
almcl
Aircon compressor
Postby almcl » Tue Aug 07, 2007 8:13 am
With the ignition off and thus no power to the compressor clutch, the pulley should turn reasonably easily.
If yours doesn't, it might be that a seized compressor was what led to the belt failure...
Al McL
Dave
Aircon compressor
Postby Dave » Tue Aug 07, 2007 7:11 pm
Thanks. Just looked and it's totally solid.
Any idea what make / model and where to buy from would be best?
almcl
Aircon compressor
Postby almcl » Fri Aug 10, 2007 10:39 pm
Your local air con shop can quote, so can David Manners and SNG Barrat, you'll need a regas and and might as well change the reciever drier tube as well.
Al McL
