2016 jaguar xe wing mirror glass replacement
Moderator:JohninBham
leelane588
Postby leelane588 » Fri Dec 22, 2023 5:30 pm
Hi all
Unfortunately someone has smashed my left hand side wing mirror glass, I have ordered the replacement glass but wonder are they easy to switch over being electric , heated
Any advice greatly appreciated
andypryce
Re: 2016 jaguar xe wing mirror glass replacement
Postby andypryce » Fri Dec 22, 2023 5:54 pm
Not sure on the XE, but mostly they are just clipped in, and pulling one end will release it from the clip. If so its simply a case of changing over the wires (note which goes where before pulling them off) and then it pushes back on to the clip. before removal move the glass so it is pointing inwards as much as possible, then pull the glass from the outside edge whilst pushing from the inside edge, should come away pretty easily. That's for the XF, presume the XE is the same.
XF Sportbrake 2020 / XK8 1998
Postby mike020150 » Sat Dec 23, 2023 10:41 am
Andy's description is spot on. Note the position of the locating pegs to allow the glass to sit correctly when installing the new glass. Mike.
leelane588
Postby leelane588 » Sat Dec 23, 2023 6:17 pm
Perfect thanks all much appreciated
