I recently had a large amount of servicing etc done on my car including a auto box fluid change, unfortunately the garage over filled the box resulting in fluid leaking out through what I was told is an overflow when the car is driven spiritedly and the box gets a little extra heat in it.
My question is how do I drain a small amount of fluid from the box? it has been suggested the drain plug is not the best option but I don't know how else to tackle it.
The garage that did the work is 140 miles from me so I don't really want to have to drive up there if I can do it myself.
Too Much Auto Fluid
Michael
Current
Jaguar XK8 4.2S Convertible
Polaris Ranger
T6.1 VW Campervan
Current
Polaris Ranger
T6.1 VW Campervan
Too Much Auto Fluid
I would just let it out the drain hole. It is going to be a bit messy but this is the easiest way.
Let a bit out and see where it is on the dip stick. If you over do it you can always top it back up.
Of course it helps if you have a ramp / trolley jack stands etc.
chris211083
Too Much Auto Fluid
ok, this is how you do it!!!!!
you need a pump i.e. windscreen washer/fuel pump. a battery 12v and a smallish tube!!! you can syfon the fluid out of the dip stick/level check tube. by inserting the length of tube down into the hole, by blowing down the tube you can tell when the pipe is submerged. then attach to the pump and place the pump in a bucket. then attach the battery to the pump and when there is enough out then disconnect the battery and check the level. before starting this:
1. start engine and drive round until engine is at the norm. this will make sure the gearbox is warm.
2.make sure you are on the flat.
3. make sure after the process is done that you check the level useing the hot scale on the dipstick.
job done without going under the car, jacking the car up or makeing a mess!!!
hope this helps.
hope this helps.
BRG XJR-S 6.0 1989 ZYTEK UNDER RESTORATION. Manual Gearbox. 12 branch Exhaust Manifolds.
Too Much Auto Fluid
My Thanks to both of you.
I do have my own 4 post ramp but I was told that the drain plug is a all or nothing plug so could get very messy.
I have a plan which I will try tomorrow using as suggested a long tube down the dip stick pipe and I am going to connect it to a large syringe, if that fails I will try a pump.
Thanks again
Thanks again
Michael
Current
Polaris Ranger
T6.1 VW Campervan
Current
Polaris Ranger
T6.1 VW Campervan
Too Much Auto Fluid
Success with the syringe.
I have removed 2000 ml of fluid which seems to have corrected the level.
Thanks again
Thanks again
Michael
Current
Polaris Ranger
T6.1 VW Campervan
Current
Polaris Ranger
T6.1 VW Campervan
Too Much Auto Fluid
Two Litres?!!!
Boy, did they overfill it - are you going to name the culprits?
Tony
Two Litres?!!!
Tony
XJS Bulletin Board Moderator
Too Much Auto Fluid
OOP's
Should ware my glasses more, 200 ml so far Not 2000 ml
I need to get the gearbox up-to temperature to see if I have taken out enough fluid, so will let you know final tally.
Michael
Current
Polaris Ranger
T6.1 VW Campervan
Current
Polaris Ranger
T6.1 VW Campervan
Too Much Auto Fluid
It just shows how careless and numb some garages are.
Did they not think it was a good idea to top up gradually and check the progress?
These spanner monkeys obviously looked at the manufacturers suggested volume for the gear oil and just tipped the full amount suggested in.
Anybody with anything in there coconut, should be able to figure out that even though you have drained the gearbox or engine, you are always going to have a residual amount/coating over the components and inner casing.
So OBVIOUSLY
you may not need the full specified manufacturers volume.
It is obvious isn't it? or is it just me.
Spanner monkeys.
I think i would start using your ramp a bit more Michael, if time allows and do your own maintenance given some of the problems you have had recently, with work done by so called professionals.
So OBVIOUSLY
Spanner monkeys.
Too Much Auto Fluid
200cc (less then 1/2pint) extra doesn't sound enough to cause an overflow from the breather? Time will tell though and hopefully all will now be well.
Hopefully you haven't noticed a drop in coolant? it's not unknown for the transmission cooler in the radiator to fail
or perhaps its leaking from somewhere else.
Too Much Auto Fluid
I should explain that the box started overflowing just after the work was done and I did take the car back but it was suggested that the worst was over and no need to worry.
Subsequently I have found that it only happens when driving in a spirited fashion and I guess the gearbox gets a little warmer.
I have rechecked the fluid level again today and I have not taken enough out so off to suck out more.
I will keep a running total just to see how far over it is accepting that some has already escaped.
Michael
Current
Polaris Ranger
T6.1 VW Campervan
Current
Polaris Ranger
T6.1 VW Campervan
Too Much Auto Fluid
I removed another 250ml of fluid today and the box is now showing the correct level.
So the total was 450ml plus whatever got burnt off while driving.
Michael
Current
Polaris Ranger
T6.1 VW Campervan
Current
Polaris Ranger
T6.1 VW Campervan
