Gearbox Warning light - Intermittent
Posted: Wed May 06, 2009 10:12 am
Help Please. Suddenly I get on MOST, but not all, cold starts the dreaded gearbox warning light shining and car is held permanently in 2nd gear until the engine is turned off. The problem may or may not recur on re-start, but usually clears after several re-starts. Logically this seems like a "silly", something loose, or dry-jointed etc. but who knows ??
I note that if the problem is going to occur, the warning light flickers very briefly from low to higher intensity when the ignition turned on. If the problem is not going to occur, the warning light is of a consistent intensity and is quickly extinguished.
My Independant Jag Serice company say that this could not be sorted unless the problem is PERMANENT, and only then with the help of some firm who happen to have the relevant Bosch Diagnostic machine.
I did have a similar problem once with an XJ40, but it "went away" quickly - but this one is now over a week old. Anybody had the same problem and found an easy cure ??
