The dreaded warning lamp
Posted: Thu Jun 19, 2008 12:45 pm
by extratime1983
The auto transmission warning lamp has started to illuminate. This is coupled with having idle problems.
The transmission is selecting a gear no problem, including reverse. I don’t want to drive it and am waiting to hear back from the garage.
Posted: Sat Jun 21, 2008 7:30 pm
by extratime1983
I now have the car home, having established it was safe to drive with the lamp on. Its a wonder what you can learn by reading the manual
I believe the two common problems are (1) the connector to the gear box, accessed from beneath the car, and (2) the transmission power relay located at the rear of the car.
Before I start removing connectors, can anybody advise the exact location for these.
In addition to the above, I am also having an idle problem. The car when warm occasionally idles round about 400rpm, then cuts out. Could the two problems be connected or is it a coincidence?
The car is a 1994 4.0L coupe
Posted: Sun Jun 22, 2008 6:01 pm
by nigel1
The connector to the gearbox is close to the gear box sump, sorry, but I cannot remember which side, and I only checked it about 4 weeks ago, but once your under the car, you'll spot it. The connector is the type which has a round collar, you need to turn the collar and then pull the connector clear.
The tranny power relay should be in the above the right hand rear wheel arch. Open trunk, remove the trim from the forward end of the trunk right hand side in the region of the wheel arch. Should be three relays tucked in there. The fwd one is Silver Colour, thats for the fuel pump, the next is light blue, for the rear lights, and the after most one, again light blue, is the tranny power relay.
Not sure about the idle issue, is the car an AJ6 or AJ16 engine. If AJ6 you could try resetting the idle air valve. The only thing I can think of which ties engine RPM to gear box is the Throttle Position Sensor, but that has two seperate pots, one for gear box and one for the ECU
Posted: Sun Jun 22, 2008 6:23 pm
by extratime1983
Thanks for your help Nigel. The engine is an AJ16
