New to XJS's this year, although last 5 years have seen good practice in keeping a Spitfire 1500 on the road!
Have a 1994 4.0 Coupe 2nd version facelift with AJ16
I'd like to check the level of the oil in the diff, but can not see any reference to this in the service manual.
Is it the usual? Remove the plug and if no oil seaps out then add oil until it does?
Have no pit or ramp so can I get access to perform this on the driveway?
Thanks,
Mike.
Rear Axle - Oil Level & Top Up
Hi Mike, thats about it, there are two plugs, obviously the one on the bottom is the drain, and the one tucked away at the rear of the casing is the filler plug.
It should be 1.6 litres from empty to full, with the car on a level surface, when oil starts to leak out of the filler hole, then your there.
I found easiest was to fill is using a funnel and short length garden hose, run the hose through the bottom of the boot (out through the centre drain/vent, remove the rubber thingy, obvious when you look), and then into the diff casing
Warm the oil prior to pouring.
See previous thread re. the diff oil
