Postby almcl » Tue Feb 28, 2012 2:41 pm
Nick
I replaced the rear axle cage on my SIII XJ (same as a pre-facelift XJS) a little while back. I have no special tools, just a normal pair of axle stands and a 2 ton trolley jack.
Jack up under the tie plate and insert axle stands under the jacking points. I then inserted a block or two of wood between the jack saddle and tie plate and jacked again, increasing the height of the stands.
The really time consuming bit was disconnecting the exhaust pipes, although eventually an air chisel helped separate the joints. Getting the radius arms off at the front was too much of a challenge, so I undid the rear ends.
After dropping the cage, using the trolley jack, I was able to extract the cage sideways. This meant that the car didn't need to be very high up.
I actually swapped one cage for another (which I had rebuilt in slow time) all told, working slowly by myself it took about 3 days.
Al McL
