V12 breathing
Posted: Fri Sep 09, 2005 2:58 pm
by Alistair
I have not a problem,merely an enquiry as to the thoughts and feelings of anyone with a V12 who has or is considering "piping up" the air intake trumpets/air filters.Is it as daft as it sounds?Does it make sense?Is it too much trouble?Our friends over the pond seem to be very keen.
Has anyone done this?
Would I be outcast as a leper or heathen if I were to do it?
Would the car/driver benefit from this mod?
Should I also consider larger throttle bodies as well as?
Maybe a "smart" ECU chip would further assist?
PLEASE DO NOT MISJUDGE MY REASONS FOR THESE THOUGHTS,I AM SUITABLY IMPRESSED BY THE MACHINES' OVERALL CAPABILITY AND PERFORMANCE, I JUST FEEL IT COULD BE A TAD MORE RESPONSIVE.
I AWAIT YOUR SENTENCE WITH BATED BREATH!
Alistair
V12 breathing
Posted: Sat Sep 10, 2005 8:29 am
by Wards287
Have alook at the AJ6 engineering web site.
www.jagweb.com/aj6eng
They supply the parts required and explain why so this may help.
Rob
V12 breathing
Posted: Sun Jan 01, 2006 10:23 pm
by hyperxjs
Dear alistair
you can gain sum bhp from direct air in to the inlet manifold but you need to open up the inlet box's or use the later 90 Deg bends and pipe to front of car so that it has cold air also we put a front loading air filter on the end of pipe
hope this helps paul.
Re: Breathing
Posted: Fri May 05, 2006 7:18 pm
by poprivet
Six double choke webers, down draught, tubular headers etc gives mine all the air it needs
Oooo! We need more information and pictures! :D
Pop
Posted: Fri May 05, 2006 9:33 pm
by Jon
I heard that the 6.0 XJR-S inlets were larger and apparently give a worthwhile breathing improvement to a 5.3. However getting hold of such parts might be easier said than done 8)
TOO LITTLE AIR INT THE BOX
Posted: Mon May 08, 2006 5:52 pm
by hyperxjs
Dear jon
call me on 01844 278481 i have top rail and boxs to fit 6 lt
they are not so much bigger but get the air from the front of rad
best regards paul ps
had the fastest xjs at croft the week end
