Starter motor intermittent
Posted: Mon Sep 06, 2010 1:40 pm
Hi lavishing care on Jezebel (1986 cabriolet) has been rewarded in the usual fashion.
Having fitted new fuel injection hose to the injectors, changed the oil and filter, and then spent time trying to buy new seals to stop Yvonne being soaked when I pulled away after leaving the car standing in the rain
Jezebel would deposit a considerable amount of rainwater in her lap. No wonder she is suspicious of traveling in her.
Finally spent money on seals from Seals direct, and made up replacements.
Well the Beaulieu Autojumble is coming up and I decided to raid the savings and use Jezebel to travel there later this week.
After I had cleaned and polished her, the thanks was a refusal to turn the engine over.
Must be the starter relay? or the ignition switch? Triumph of hope over experience here.
Investigation showed that they were fine, Jacked the car up, placed on axle stands lay on my back and peered up into the gloom. There was a cover obstructing the connections. Struggled with the cover and finally removed it.
Still couldnt see much pulled on the wires to see if they were loose. No movement.
Went indoors for a cup of tea and a moan. When I returned I idly tried the key she fired up. Tried her again over the next few hours. Always starts.
I suspect sticky solenoid, I know from past experience that it will fail again. This happened to my Pre-He. car.
Any suggestions where I can buy a reliable recon starter motor?
I wish it was a manual at least it would then bump start.
Regards Kels.
Ps reliable old Landcrab is being pressed into service for the journey.
Regards Kels.
