Hi everyone, e.mailing from a very cold and icy Co. Wicklow.
I have a 96 XJS that starts first thing in the mornin however, on cold mornings like now it cuts out when I engage drive, once the engine heatsup it's fine but when cold and I engage drive if I put my foot on the brake pedal to sto at the gate or crossroads it dies.
Very grateful for any ideas, perhaps it's a sensor or such like?
Cutting out when cold.
What is the idle speed at first start up? Might be a bit low so when coming to a stop it dies.
I think warm idle speed is 750rpm and cold idle should be faster (not sure what it should be though)
Might be the aav sticking and not opening fully.?
1978 XJ-S V12 Auto - Under Restoration
Assuming your car is a 6 cylinder?
The idle speed is supposed to be regulated by the ECU to take account of the extra drag from a cold engine, engaging the transmission, etc.
So, does the cold idle vary when engaging gear? If so, from what to what?
If it doesn't, then is the coolant temperature sensor performing within spec? This can have quite an influence on fuel mixture, especially with a cold engine, and a weak mixture here can produce a stall.
I am not sure if the 96 cars retained the idle stepper motor, if they did, is yours functioning correctly? This sets the idle speed control valve 'at a position suitable for engine starting'. If yours is sticking this might also produce the symptoms you describe.
Al McL
