Oil Pressure Indicator
Milan
Postby Milan » Wed Apr 30, 2008 7:29 pm
My oil pressure gauge is reading approximately 75-100% over the maximum figure indicated (it goes from zero to eight). Any idea what the cause of this might be?
Green 94 XJS 4.0 Facelift
almcl
Postby almcl » Wed Apr 30, 2008 10:56 pm
Not quite sure I understand where your needle is?
Beyond the 8?
Round at the 4 o'clock position? If this last then the gauge is likely broken.
http://www.jec-xjs-forum.org.uk/xjsbb2/ ... 3-1_tn.jpg
It's calibrated in hundreds of kilopascals so 6 is the equivalent of 87 psi, 8 is nearly 120 psi. What weight oil are you using?
Al McL
Milan
Re: Oil Pressure Indicator
Postby Milan » Wed Apr 30, 2008 11:52 pm
Beyond the 8?
Yep... i've altered your image to indicate where the needle is (see the bogus, doctored needle I've added on the right of the following image!):
http://www.milan.bz/gauge.jpg
10w/40
extratime1983
Postby extratime1983 » Thu May 01, 2008 12:09 pm
I would suggest the gauge is broken. Is it likely that the engine had a surge of pressure to do this. I ask because I work in the chemical engineering industry and this can happen when one of our pumps goes over operating pressure.
Thoughts from other members.
Milan
Postby Milan » Thu May 01, 2008 12:14 pm
Thanks for the reply. I noticed this morning that the needle is stuck in that position after I switch the ignition off, so I guess it's broken unfortunately!
Milan
Postby Milan » Tue Jan 27, 2009 5:24 pm
So... I had the oil pressure sender replaced last June and all was well until last week when the gauge went tits up again. I've just checked my oil level and noticed that it's horribly low (the dipstick barely registers anything!).
Any thoughts as to what might be the root cause of this?
nigel1
Postby nigel1 » Tue Jan 27, 2009 9:59 pm
Begs the question, when was the last time that the oil level was checked?
You have to expect some loss in oil, especially in an engine that is now 15yrs old.
Regarding the Oil Pressure, the gauge itself is pretty reliable, the sender unit is usually at fault. If you can find one, fit the old style which reads oil pressure directly, the newer type have a resistor wired in, (easy to see, its in the harness). The new type were designed to indicate an oil pressure at mid scale on the gauge, no matter what the actual pressure was (unless about zero), in other words, acted pretty much as the oil pressure switch
Postby ptjs1 » Wed Jan 28, 2009 12:11 am
Good reply, Nigel
Not many people are aware of the upgraded sender unit. It was developed by Jaguar in response to complaints by customers that their oil pressure was going down at hot idle and fluctuating under different heat conditions...which it should be expected to do!
So they cheated and decided to introduce a sender that basically read at 4 bar even if the real pressure is anything just over about .25 bar! Dealers were told to fit this sender if the customer complained of fluctuating oil pressure so they went away thinking their engine was miraculously improved!
Milan, as regards the oil level; you don't say if you have an AJ6 or AJ16 engine and there may be no difference; but on the AJ16 engine the markings for correct oil level are quite low down on the dipstick. Basically if it's anywhere in the rather small hatched area when cold, then it's about right.
Maye there's a fault in the wiring or sender connection which is causing the gauge to go wrong. As suggested, if the oil level is right, I'd replace the sender again, check the wiring and see what happens.
Milan
Postby Milan » Wed Jan 28, 2009 12:21 am
Many thanks for the replies.
I'm ashamed to admit that I left it a couple of months I'm afraid. It was over Christmas, we moved house, and the wife and I had our first baby, so the big cat probably received less affection than she deserves!
If it's anywhere in the rather small hatched area when cold, then it's about right.
Yeah, it was even lower than that! I had to put in a good 2 litres to get it back to normal, which isn't very promising. Would you believe, I somehow managed to reverse into a tree today too - it just hasn't been my day! (Luckily, I was moving very slowly, so I only caused a tiny scratch).
almcl
Postby almcl » Wed Jan 28, 2009 11:37 pm
Milan
I'm slightly confused here, you had the sender rather than the gauge changed to correct that 4 o'clock indication? And that corrected the problem? If so, I think the gauge is still suspect.
As regards oil level, if it's going down, it's either leaking or it's being burnt. AJ6/16 engines are pretty good usually about burning oil (I got my first one to 180,000 miles before selling it and its consumption was still OK, although quite a lot depended on how it was driven - short journeys tended to push up consumption.)
A leak ought to be more obvious - staining on the ground under the car etc
Al McL
Milan
Postby Milan » Tue Feb 17, 2009 1:31 pm
Just had the car back from a 10k service. I asked the garage to look into the oil pressure sender, but they said the gauge itself was at fault, so they replaced it.
Upon firing up the car last night when they dropped it off, the gauge worked perfectly. However, I started the car this morning and yes, it's gone again!
Bloody annoying....
