AJ16 revving when car stationary
Posted: Thu Aug 11, 2016 2:10 pm
by DavidCosham
I've just purchased an XJS Celebration convertible from another member. The car's in great condition but I've noticed the engine sometimes revs to 1500rpm when supposed to be idling. This means I'm braking hard against the engine to come to a stop which can't be a good thing.
Are there any simple adjustments I can make to solve this, or do I need an engineer to look into the problem?
Thanks, David
Re: AJ16 revving when car stationary
Posted: Thu Aug 11, 2016 7:53 pm
by steve_m
One option could be the throttle butterfly being gunked up and sticking.
Posted: Thu Aug 11, 2016 9:07 pm
by davidr
Probably needs either the throttle body and butterfly cleaning because it's bunked up or it could be the idle valve.
In both cases it will need to be removed and cleaned using carb cleaner. That's the first thing to try before you start spending money!
Posted: Fri Aug 12, 2016 8:35 am
by Brakebuster
also worth checking the carpet under the accelerator pedal for anything stopping the pedal from fully returning to the idle position ,
the carpets can work their way forwards fouling on the pivot point
Posted: Sat Aug 13, 2016 7:43 pm
by Tintin
The butterfly may stick open with the engine idling but close smartly under return spring pressure with engine off - best to check both scenarios, which may aid diagnosis. Jaguar issued a bulletin for stronger throttle return springs to be fitted to some early AJ16 engines - weak return spring pressure may be a factor/cause.
Robbie
Posted: Sat Aug 13, 2016 10:12 pm
by davidr
It's fairly common for the spring to weaken. The answer is to wind it round another turn.
