Service tool JD-41 Cylinder liners retainers
iRS
Postby iRS » Fri Apr 08, 2016 8:05 am
I'm in the process of stripping my engine - as part of a larger project to restore a '76 car. Does anyone have the above service tool to lend, loan or sell? These are the bits to make sure the cylinder liners do not move when the engine is turned with the heads. The heads are still to come off, so it may be a while until I need them!!!
Roger
Roger S
Aberdeenshire
Early E
X350 - 2005 Super V8
1962 MGB
Re: Service tool JD-41 Cylinder liners retainers
Postby ptjs1 » Fri Apr 08, 2016 3:56 pm
Roger,
Ken Jenkins definitely sells them and I think he might also hire them out. Give Ken or Annie a ring on 01909 733 209.
PS Have you taken over as the XJS Forum Co-Ordinator from David?
iRS
Postby iRS » Fri Apr 08, 2016 8:19 pm
Thanks for that suggestion.David is still forum coordinator. I am an extra helper. Richard is still involved too, so there are 3 of us in total. The next magazine should clarify too.
I tried contacting Annie/Ken about these and other tools. They didn't seem to have any for rent, but I didn't enquire about purchasing them. On the other hand I did try Barratts (to purchase) and they said they are out of stock at the moment. I would rather borrow or rent as I hope it will be a one-off!!
Roger
Roger S
Aberdeenshire
Early E
1962 MGB
oldtimer
Postby oldtimer » Fri Apr 08, 2016 9:26 pm
Roger,
When you get round to this job I shall be very interested to hear about the ease with which the heads are removed !!
Oldtimer
piman
Postby piman » Sat Apr 09, 2016 7:57 am
Hello Roger,
I don't know the V12 (I assume?) engine but the old school way was simply bits of steel tube and nuts and washers. A length or two of electrical conduit from a wholesalers cut up would be a lot cheaper than dedicated 'special tools' I would imagine?
iRS
Postby iRS » Mon Apr 25, 2016 3:19 pm
Alec and Oldtimer - I'd been waiting for a bit of progress before replying. Its taken a while, but I do now have the heads off with no more than a 4 x 4 (bit of wood, that is not an off-roader!) and a large hammer:
Other than a high degree of carbon, the engine looks largely OK. I think I got lucky as only one or two studs each side were dragging and you may be able to see white residue on some of the studs. The ones at the ends that do not run in the water jacket look like new. I think I am lucky in that the Jaguar service schedule involving Bars Leak was probably not followed too enthusiastically. Once the seal was broken, I could feel the heads rocking on the one or two studs that caused the sticking and a bit of persuasion with a hammer did the rest.
Alec - I'm not quite clear on the use of conduit to make the liner retainers. Could you elaborate please?
Roger S
Aberdeenshire
Early E
1962 MGB
piman
Postby piman » Mon Apr 25, 2016 4:52 pm
Hello Roger,
slide a washer over the stud, large enough diameter to rest on the liner, cut a length of conduit about 1" shorter that the length of the exposed stud, another washer on top of the conduit then snug a nut down onto the top washer. This retains the liner when you rotate the engine. A bit of work on a V 12 but I would guess the option of a specially made kit won't be cheap.
PS, just looking at the engine picture, if you can get large enough washers do a pair of cylinders at a time, that way you'll only need three retainers per bank.
oldtimer
Postby oldtimer » Thu Apr 28, 2016 9:27 pm
Roger,
Pleased that you have managed to remove both heads without to much grief. I have heard of incidents where heads have proven almost impossible to remove.
Best wishes with the rest
Oldtimer
iRS
Postby iRS » Sun May 08, 2016 8:13 am
So to round off this thread, penny washers and steel tubing bought on eBay for £23 pounds and liner retainers made. The tubing is 15mm, 2mm wall and I have doubled up on the penny washers (50mm x 2mm).
I can now turn over the engine without the liners moving. Now to dismantle some more..................
Roger S
Aberdeenshire
Early E
1962 MGB
oldtimer
Postby oldtimer » Sun May 08, 2016 9:33 pm
Roger,
Do tell us a little more !
Why did you decide to open up the engine ?
What state are the bores in ?
And the heads etc etc
Oldtimer
iRS
Postby iRS » Mon May 09, 2016 8:59 am
HI Oldtimer,
Good points. I decided a while ago to have a go at restoring an early XJ-S, more for my own satisfaction and a challenge than anything else. As part of this, I decided to thoroughly inspect the engine. So against the better advice of far wiser Jaguar experts than myself, I decided to lift the heads to inspect the bores and heads. The bores look good. Minimal wear. The heads seem fine, but I will need to check them for trueness at some point. One thing I'm thinking of is to upgrade the rear crankshaft seal. I believe this is quite an arduous job and involves machining both the crank and the block. Given the state of the gaskets, I'm glad I did take the heads off. I can't believe they would have lasted much longer and it would be a shame to have to do the gaskets after getting the engine back in after the restoration. I'm projecting ahead, it will be a while yet..........
Roger S
Aberdeenshire
Early E
1962 MGB
oldtimer
Postby oldtimer » Mon May 09, 2016 9:48 pm
Roger,
I shall watch very carefully for your progress and I shall tell you for why. I have a XJ12 on carbs and currently have a miss fire on No 3. I am looking at all the possibilities but am reluctant to carry out the acid test of a compression test for fear of finding something I don't want to find. As we all know it is a monster lump of bits and pieces all screwed together. I have all the gear to do the job together with an overhead gantry but at my age I a bit nervous about even starting !
Oldtimer
iRS
Postby iRS » Wed May 11, 2016 10:00 pm
Oldtimer,
I think there are so many horror stories about V12 heads, that the times they have come off with relatively little problem are quickly forgotten. So I hope my experience does serve to demonstrate that the heads will come off without a drama. You should go ahead and do the compression test, so at least you will know. If you need to pull a head, then you will need to decide whether to do it without removing the engine. I would not have got the heads off in the car as I would not have had access to use the bit of 4x4 and the hammer. However you could rent the head puller (£100 per week from Ken Jenkins) and do it in situ. At least with your set up you do not have all the fuel injection to deal with. I still do not understand the fuel injection system on my car, but I guess I'll figure it out when i put it back together!
Roger
Roger S
Aberdeenshire
Early E
1962 MGB
oldtimer
Postby oldtimer » Wed May 11, 2016 11:02 pm
Thanks Roger
PaulGover
Postby PaulGover » Fri May 13, 2016 1:26 pm
I have a theory that flushing the cooling system with Fernox (active ingredient malic acid) would shift enough corrosion products from the studs and joints to make getting the heads off easier - though more so on the iron/aluminium mixture of the XK engine than on the all aluminium V12. Fernox is really effective; when I tried it on our boiler some years back, one of the pipes turned out to be all rust, and dissolved away in less than 15 minutes!
