V12 Engine Advice needed
I have not started my V12 Engine for about 6 years, it was running ok last time it was started, has anyone got any advice before I try to start as I dont want to do any major damage.
Re: V12 Engine Advice needed
Hi.
There are 2 ways of doing this:-
Stick a new battery in the car, cross your fingers, say a small prayer to whichever God that you believe in and see if it will start. Not really recommended.
Or, do a partial rebuild. You will probably have stuck injectors and throttle butterflies, there will be water in the fuel and probably the oil, the anti-freeze will have gone way off, the fuel pumps are probably seized and the exhaust knackered.
Sediment in the cooling system will have solidified, thermostats will be stuck and the electrics in an unknown condition.
It might be worth removing the fuel pump relay (or pulling up the cap on the inertia switch) to see if it will actually turn over on the starter; if it is seized then you will save an awful lot of time by putting another lump in it.
Steve
Steve
I dont want to put another engine in it as I have had the car since 1991 when it had done 2k miles,it has only done just over 60K now, I will try the other options and see how it works out.Hi.
Steve
See if you can turn the crank via the nut on the pulley.
If 'yes', change oil, filter, coolant and get some fresh fuel. Then try and start with a good battery.
If it starts and runs, change the brake fluid, check the tyres for flat spots and replace as needed, then book in with your nearest friendly MoT station.
Collect car and list of failure points, decide which to pay him to fix and which to fix yourself.
Once Mot is issued, regas air con, promise yourself that you won't leave it standing as long next time. Fix remaining minor niggles.
Al McL
Cheers, I will try that and see what happens, once I get it running I promise i won't leave it standing again.See if you can turn the crank via the nut on the pulley.
I read somewhere that taking out the spark plugs and squirting in a little oil, and leaving for a few hours can help un-seize piston rings ((if they are have bonded a little to the cylinder bore) prior to cranking....
Good luck.
Rich.
PS - I leave my V12 for periods of up to six months without issue. I make sure that that I only have (max) quarter of a tank of fuel, two protective covers (one in-door soft cover , one out-door heavy duty on top), a CTEK battery conditioner, two dehumidifier tablets (one in the boot, the other in passenger foot-well), tyres pumped to 40psi and garaged. Oh - and a good quality wax on the paintwork..
Good luck.
Rich.
I have been told this before about squirting oil on the top of the pistons,I will try this as well if I can get the plugs out which I think can be awkward.I read somewhere that taking out the spark plugs and squirting in a little oil, and leaving for a few hours can help un-seize piston rings ((if they are have bonded a little to the cylinder bore) prior to cranking....
Good luck.
Rich.
Just returned from holiday in the sun,thought I would try and crank the engine as recommended, it was a bit tight at first but managed to turn it ok using a ring spanner, I will do all the other recommended tasks and see if it fires.
Users browsing this forum: No registered users and 39 guests
